Fox body to Sn95 motor and drivetrain swap? - Mustang Evolution
Old 07-08-2015, 09:21 AM   #1
robq23's Avatar
So I have a 89 gt and i am looking to swap my motor and tranny and what ever else possible into a 95 gt. I know the 5.0 and t5 should go just fine, but what about my bbk shorty headers, aluminum drive shaft, rear end, motor mounts , and possibly suspension? I just bought bilstien shocks and struts and eibach sport line springs for my fox. I'm also worried about the sn95 wiring harness not hooking up to my motor ? How many have done this swap and what problems have you ran into ?
robq23 is offline   Reply With Quote
Old 07-09-2015, 07:43 AM   #2
Most of the stuff swaps over, not sure about the suspension stuff as I have not actually ever done that. It probably will but if you can return it I would. If not then try it and if it doesn't fit then sell it.
As far as swapping the motor/trans/driveshaft and mounts. They all swap over with a few gotchas. You'll need to mess with the IAT sensor location a little and the front covers/accessories are different. Also the throttle body/egr assembly and the upper intake are different setups. If the 95GT you have has a motor in it you can just swap all the 95 stuff over or you can use the fox intake/tb setup.
Now as far as the trans/driveshaft... like I said they will fit. But you will need a 5/8" driveshaft spacer and your shifter will sit further forward. Since these cars are known for having issues with reaching for the shifter, this is not exactly ideal. However you can buy a Steeda shifter relocation plate (for the any TKO or any Hurst shifter) and modify it to fit any shifter with some nylon spacers. You will also need to use your fox bellhousing and clutch fork if you use a fox trans. You may also run into crossmember issues and driveshaft alignment with this setup but you can always buy a Stiffler's one that will have enough adjustment and shims to probably be fine.
Exhaust all bolts up but you will not be able to use EGR which is not really an issue but you will need to tune it out.
Electronics wise everything pretty much just bolts up especially since you have a donor car just use all the 95 electronics and anything that isn't quite right on your fox motor just swap the SN95 part from your 95 to it. I will say that the 94/95 computers suck *** tho... you can either tune them or you can put your fox ECU in which will need a minor re-pin along with a standalone fan controller and BAP sensor. I have the diagrams and I can post them when I get home if you need them. I highly recommend swapping to the fox computer.
So in a nutshell, yeah you can swap most/all of your stuff but its not 100% bolt in. It is close tho.
Old 07-09-2015, 08:14 AM   #3
robq23's Avatar
Okay good deal. I'm expecting a few hiccups but I just didn't know if anything major would come upon me. And as far as the 95, it has no motor and everything on my 5.0 is just a few months old so I plan to use all I can.
Old 07-09-2015, 08:45 AM   #4
Hmmm yeah then you'll need to run with the fox TB setup and fox accessories which should work fine. You WILL want to convert to a 94+ alternator though, even if you were keeping a fox you'd want to do that. If not you'll have charging issues out the ***.
The rearend will work but you will need to 5 lug it if it isn't already. There will be a few other things but nothing major. Basically just that driveshaft spacer and the crossmember will give you fits but I'd just buy the Stiffler's.
Old 07-09-2015, 01:03 PM   #5
robq23's Avatar
Good, that all makes me pretty optimistic that it should go pretty well. Thanks I appreciate it!
Old 07-09-2015, 01:47 PM   #6
Yeah the 94/95 used the fox drivetrain with minor changes so they can be swapped. Biggest thing is the trans placement and some of the electronics.
Oh, you will need the 94/95 fuel rails and whatnot as well to go to the fuel lines in the car. Hopefully your roller still has that... Like I said, there are "gotchas" but nothing major. I'm sure I'm forgetting a few other small things.
fox body
Wanted: Fox body or sn95 Cobraboy96 Mustangs for Sale and Wanted 1 02-10-2015 06:34 PM
Boss Intake/Airraid intake and throttle body question Plus Drivetrain Sterlingbeast5.0 2011-2014 Mustang GT 7 01-28-2015 11:40 AM
2000 3.8 to 2003 3.8 drivetrain swap tsams Pre-2005 V6 Mustang 3 07-24-2014 12:19 PM
Sn95 motor/tranny swap into my 88 mustang Lx? Sybesma07 1979-1995 Mustang GT 3 09-22-2013 09:14 PM
Fox body with SN95 headers.... Tbird232ci 1979-1995 Mustang GT 16 02-03-2004 07:09 PM
11:15 PM
