302 build - Mustang Evolution
Old 07-16-2015, 03:42 AM   #1
regattabluefox's Avatar
302 build
Building a motor, edelbrock heads, 1.6 roller rockers, 6.7 pushrods(used length checking tool for size) but the valve covers I have don't fit and am looking for a set tall enough to clear but short enough to clear intake. The only ones I've been able to find that are taller are for carb motors. Any info would help, kind of at a stand still
regattabluefox is offline   Reply With Quote
Old 07-16-2015, 01:24 PM   #2
olerodder's Avatar
Region: Oregon
Ford Racing Cast Aluminum Valve Covers - Free Shipping on All Orders @ JEGS
289-302-351W Valve Covers
Trick Flow Mustang Valve Cover Tall Pair 289/302/351W
I know that if you use intake spacers you can run the carb'd tall valve covers. I know that TrickFlow makes a tall cover that will fit EFI motors....not sure what the number is............give them a call.
Old 07-17-2015, 02:10 PM   #3
smurf stang's Avatar
Why don't they fit....rocker arms?
I used the standard trick flows to clear my Comp Gold 1.6. The tall covers cause problems with the intake. Then you get a spacer and make the intake runners longer which I hate.
6.7 inches seems a big long for Edelbrock heads.
2016 VW GTI 2.0 Turbo
Old 07-17-2015, 04:29 PM   #4
Hopefully he used a solid checking lifter when he did the pushrods.
Sent from my LG-D801 using Mustang Evolution mobile app
2000 Mustang GT Steeda #0048
Old 07-17-2015, 11:05 PM   #5
olerodder's Avatar
Region: Oregon
I thought 302's were 5.8".............my 408 with TrickFlow R heads used 6.7 Trend's and I had 1.6 Comp roller rockers. I just had to grind the breather stands off the underside.................wonder if he is using solid rollers?
Old 07-18-2015, 12:05 PM   #6
I think he may have used a regular hyd lifter when he checked... Hope not.
Old 07-18-2015, 01:02 PM   #7
Usually with trickflow heads the pushrods are usually in the 6.7 range as it is not like its inline brothers. With other heads and cams it ranges alot more.
Like Scotty said I hope the OP made a solid lifter.
Also with the trickflow valve covers they didn't have a breather hole or baffle. I got to drill my hole anywhere but I installed a catch can so it didn't matter.
Sent from the Bathroom
Old 07-22-2015, 02:11 PM   #8
Found the problem with the valve covers. Stock ones fit, I had a pair that I thought were stock size that I tried while mocking up but they weren't. They had three threaded holes that stuck out of the inside. Threw stock ones on for ****s and giggles and they fit. The Edelbrock heads have the 7/16 studs, tried using stock length pushrods and were way to short. So you don't check the length with the lifters you'll be using? This is my first complete motor build, just trying to get it done the right way. Sorry couldn't log on to mustang evolution on my phone. Thank you for all the info.
Old 07-22-2015, 02:27 PM   #9
Here is a good read....Adjusting Stud Mount Rockers - and checking pushrod length
Old 07-22-2015, 02:36 PM   #10
You cant use hydraulic lifters to check length because they collapse when dry. They only pump up when the engine is running. You need a solid checking lifter or you will have a wildly inaccurate measurement.
Old 07-22-2015, 03:26 PM   #11
Thanks bud, guess I needa regroup a little, done a lot of reading and watched a lot of videos about pushrod length etc. any other info on 302 builds appreciated. Started out as a bare block that I didn't take apart, and it's my first time fully assembling a short/long block myself.
Old 07-23-2015, 04:07 PM   #12
Look at the link I sent you.
Good luck and keep us posted.
Old 07-24-2015, 05:54 PM   #13
Will forsure let you know how it goes. It's not popping up as a link, I can't get the me app to work so I'm just on the internet.
Old 07-24-2015, 06:08 PM   #14
That link he posted is the correct method and using stud mounted rockers is SO much easier than pedestal. I would only use pedestal rockers in an application where they had to be used.
86 302 T-5 build 1K budget Jrod.86GT.99 1979-1995 Mustang GT 10 01-21-2015 03:04 PM
Ford 302 build problem Haav2 1979-1995 Mustang GT 8 01-18-2015 11:20 PM
Build a 302 roosterisme2001 Classic Mustangs 6 01-10-2014 04:16 AM
Can I build a high performance 302 with an old block from 1983? rashane 1979-1995 Mustang GT 2 12-13-2011 07:21 PM
What 302/5.0 block to build? ragtopstang 1979-1995 Mustang GT 13 12-22-2006 11:30 PM
06:00 AM
