Oil pump - Mustang Evolution
Old 07-22-2015, 07:59 PM   #1
1987mustanglx50's Avatar
Oil pump
Am needing to replace my oil pump on my 1987 mustang lx 5.0 ASC McLaren vert what is easier way to replace my oil pump by dropping the front end suspension or by just removing the motor ? Any help thanks in advance
1987mustanglx50 is offline   Reply With Quote
Old 07-22-2015, 09:59 PM   #2
Both ways are about equal. Does any other maintenance need to get done on it? Rear main seal? Clutch? Pull the motor and do anything that needs done.
2000 Mustang GT Steeda #0048
Old 07-22-2015, 10:41 PM   #3
Oil pump
No the transmission was just rebuilt and motor work none beside the oil pump
---------- Post added at 08:41 PM ---------- Previous post was at 08:40 PM ----------
Thank you for the input I will more than likely go with pulling the motor
Old 07-23-2015, 01:53 PM   #4
Personally I'd pull it.
You want a high performance standard volume pump btw. IIRC the Melling unit costs $40. I'd also put an ARP shaft in while I was at it but that's just me.
Dropping the K is a royal PITA and you are working under the car and everything sucks. The way the pickup is in the motor, you'll think it is clear but the pan will catch on the pickup and then not clear the K and you'll want to light the whole thing on fire. Pulling a motor/trans out of a Fox is pretty much just a matter of dropping the mid pipe out, undoing the motor mount nuts and then unhooking a few coolant lines and electrical and out she comes.
Old 07-23-2015, 02:15 PM   #5
I was thinking of just taking out the engine to its seems less painful to me to thanks for the input
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 12:37 PM
Oil pump screen help mmmchia Pre-2005 V6 Mustang 1 09-08-2009 12:29 PM
Broken OIL PUMP 67mustang97 1996-2004 Mustang GT 5 07-11-2008 04:52 PM
WTB: Electric Air Pump (smog pump) MagnuM Mustang Parts for Sale and Wanted 0 05-16-2007 11:10 AM
12:37 AM
