Transmission Question - Mustang Evolution
Old 07-23-2015, 03:21 PM   #1
silvrbullet2012's Avatar
Just got myself another 2.3 mustang. This time a manual. So my question is. They say the 1993 trans is a T5 just weaker from the 5.0. So does that mean I can buy a GT shifter and work on mine? I'm planning sooner or later a 5.0 swap. Just looking to play with this while I have it.
silvrbullet2012 is offline   Reply With Quote
Old 07-23-2015, 04:09 PM   #2
The 4 banger trans is much weaker. The shifters are all the same regardless of what t5 it is tho.
Sent from my LG-D801 using Mustang Evolution mobile app
2000 Mustang GT Steeda #0048
Old 07-23-2015, 05:20 PM   #3
Awesome. So whenever I do the swap Its just another piece I can use too.
Old 07-25-2015, 11:52 AM   #4
wbrockstar's Avatar
I would either buy just a shorter shifter handle & leave the rest of your shifter assembly in place or buy an aftermarket shifter(Hurst,pro 5.0,Steeds Tri-Ax)that provides positive stop bolts,shorter throws & a firm feel(no sloppy feel like stock)goes from 2nd to 3rd gear almost by itself,no forcing it into gear.You would also be able to transfer this shifter from the current 4 cylinder t5 you're running over to the future 5.0 t5, once you buy one to mate up with the future 5.0 engine.A aftermarket shifter feels 150% better than the stock shifter.
Mustangs Unlimited - The Premier Source for Mustang, Shelby and Cougar Parts and Accessories
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 07-26-2015, 03:41 PM   #5
I would buy a used Tri Ax for $100. Cheap, high quality and if you miss 3rd with a Tri Ax you just plain suck at shifting lol.
Can you change a manual transmission to an automatic transmission 2007 mustang? Ekon General Mustang Discussion 3 12-18-2011 04:09 AM
Automatic Transmission Question? TriStateStang Pre-2005 V6 Mustang 10 01-24-2008 01:54 PM
Transmission Question LukeB1034 1996-2004 Mustang GT 1 08-06-2006 10:46 PM
Newbie Question, Transmission? getgo 1979-1995 Mustang GT 8 07-22-2004 02:44 PM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 05:49 PM
02:55 PM
