94/95 spindles vs 96/98 spindles? - Mustang Evolution
Old 07-25-2015, 07:25 PM   #1
robq23's Avatar
So I went to a few junk yards today to see if could pick up a set of spindles for my 1995 mustang gt. Their was only 1 94 mustang and it was missing both but I had about 6 other 96-98 mustangs to choose to pull from, so what're the differences between the two? I've had a few people tell me that the later spindles offset your wheels more and have them stick out up to 1.5" wider? Should I just get what spindles I can or search more for 94/95 ?
robq23 is offline   Reply With Quote
Old 07-25-2015, 09:15 PM   #2
wbrockstar's Avatar
Youre correct on the spindles not fitting.96-04 spindles have a higher mounting location.This info is listed on Maximum Motorsports website.The 94-95 v6 & v8 spindles will fit the Foxbody to do a 5 lug brake conversion, but the 96-98 Mustang brake parts cannot be used to do this same conversion so that's more evidence showing you why a 96-98 spindle won't fit the 94-95 model.If the spindle would fit between the 94-95 & 96-98 models,it would also fit the Foxbody and it doesn't.The 99+ Mustangs do have PBR aluminum, dual piston calipers that you can use with the 94-95 spindle.You will have to use the banjo bolts that come with the 99+ caliper though,because the caliper threads are different, than the threads in the 94-95 calipers.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Fox spindles VS sn95 spindles Foxresto 1979-1995 Mustang GT 2 03-30-2015 11:59 AM
Will my w/hub fit sn95 spindles? Sybesma07 1979-1995 Mustang GT 4 09-11-2012 02:39 PM
Drop spindles??? Tyoung68 Classic Mustangs 12 10-07-2011 01:20 AM
Drop spindles Tyoung68 Classic Mustangs 0 08-27-2011 02:46 AM
Leaking wiper spindles? theopenroad Classic Mustangs 2 06-03-2008 02:16 PM
09:55 PM
