Unplugged plugs and headlights not working - Mustang Evolution
Old 07-26-2015, 09:53 PM   #1
Hey guys, just got my 89 gt tonight. Noticed fairly quickly that the headlights werent turning on. It has new bulbs and a new fuse. I cant even get an indicator on the cluster that highs are on when i switch them on. Any idea? Also, i have 2 plugs unplugged. One is coming out of the headlight cluster on the drivers side. The 3 pronged green plug is near the throttle body. Any ideas?
Sent from my SAMSUNG-SGH-I537 using Mustang Evolution mobile app
ID:	188111   Click image for larger version
Bug10 is offline   Reply With Quote
Old 07-27-2015, 09:06 PM   #2
wbrockstar's Avatar
The 3 prong plug in the second picture goes to the evp sensor which is bolted to the egr valve.It doesn't look like you've even got an egr valve.I'm not sure what the other plug is for.The headlight switch could be bad.Is the parking light & signal light both working on the driver side??You've got a wiring harness for the headlight, parking light & signal light too so if one of those aren't working, the plug likely goes to the non working light.You've also got an airbag sensor on the driver side which uses a wiring harness & the low coolant sensor inside the reservoir bottle is also in that same vicinity.What are the two wire colors on this harness??
ID:	188159   Click image for larger version
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 07-27-2015, 09:21 PM   #3
Could be as simple as the switch, would not be the first time. Pull the switch and jumper the plug and see if they turn on.
Old 07-28-2015, 07:15 AM   #4
The plug is red and black inside.
My father who's had a few of these also said its probably the switch. All of my lights are working but the actual headlights.
Old 07-28-2015, 08:19 AM   #5
Strange Mud's Avatar
Muds internet guess is when you plug in the headlight if that is where the other plug goes is you'll be on your way to finding the short....buy fuses.
Old 07-28-2015, 11:08 AM   #6
wbrockstar's Avatar
Does the wiring harness have 2 wires & look like the one shown in the picture below??If yes,it does indeed connect to the low coolant sensor.The 87-89 uses a 2 wire plug & the 90-93 uses a 3 wire plug.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
Old 07-28-2015, 11:23 AM   #7
Thats the plug. So it has nothing to do with my lights. Ran a jumper and still getting everything but headlights
Old 07-28-2015, 11:36 AM   #8
Time to start following wires. True story I had a Mustang once where something chewed up a bunch of wires in the engine compartment. Could have been some sort of critter or varmint?
A\C working then not working Bohogin Pre-2005 V6 Mustang 3 07-14-2011 01:44 PM
speedometer and gas gauge not working?? rob913 1979-1995 Mustang GT 0 07-03-2010 08:00 AM
1976 ford mustang will not start, not headlights come on, it is not the battery, why? eifion Classic Mustangs 6 08-24-2009 03:12 AM
odometer and Trip not working Tim Knox 1996-2004 Mustang GT 2 07-19-2008 12:12 AM
07:13 PM
