Driver side signal staying on instead of blinking - Mustang Evolution
Old 08-02-2015, 12:15 AM   #1
WhiteCali5oh's Avatar
Region: West Virgina
Long story short. 89 fox. Installed shorty headers and new plugs today. Unplugged battery during the install. Now, my driver signal won't flash. It comes on but it stays solid? What could have happened during the install that could cause this? Any suggestions on what to try and look at? Lol
WhiteCali5oh is offline   Reply With Quote
Old 08-02-2015, 01:15 AM   #2
natestang07's Avatar
My dad's truck did this and there was some sort of a flasher relay that needed to be replaced I believe
Old 08-02-2015, 04:47 PM   #3
Strange Mud's Avatar
have you done the obvious and checked all bulbs...when one goes out the other often won't flash
Old 08-02-2015, 04:52 PM   #4
They both stay on.
Old 08-02-2015, 05:00 PM   #5
Look in the owners manual and find the location of the turn signal flasher relay.
If all of the bulbs are working, that is likely the cause.
Old 08-02-2015, 06:11 PM   #6
I don't have an owners manual hahahah. I'll figure it out
Old 08-02-2015, 06:19 PM   #7
There should be a sticker, on the fuse panel cover, that has the fuse and relay positions.
Old 08-03-2015, 10:39 AM   #8
A burned out bulb
Old 08-03-2015, 04:32 PM   #9
wbrockstar's Avatar
The driver side front or rear bulb is probably blown.Surges can occur anytime the battery is reconnected so it might have caused a weak bulb to blow.Check the flasher too,its the round object pushed into the fusebox next to the other fuses.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Side mirrors turn signal SweStang 2011-2014 Mustang GT 1 08-17-2013 11:29 AM
No start and blinking theft light l2plagears Pre-2005 V6 Mustang 7 06-18-2012 05:15 PM
Blinking Cel and then stopped blinking on my 2012 mustang gt with less then 400 miles sleeperstatus 2011-2014 Mustang GT 5 05-03-2012 06:16 PM
O/D light blinking BigB227 1996-2004 Mustang GT 4 10-15-2011 04:23 PM
air bag light blinking jcl2669 1979-1995 Mustang GT 10 01-13-2011 11:50 PM
09:48 AM
