Rpms dropping - Mustang Evolution
Old 08-06-2015, 08:52 PM   #1
G1994T's Avatar
Rpms dropping
Help! I have a 94 gt and it runs and sounds great but when I hit the gas from a dead stop the rpms from from about 750 to 500 or sometimes lower before they go up again. It caused the car to stall a couple times. I cleaned the throttle body and it might have helped a little bit but it could also be in my head. Not sure what to do.
G1994T is offline   Reply With Quote
Old 08-06-2015, 10:05 PM   #2
I kinda have the same problem like wen I rev it the rpms go up then way down for a bit
Sent from my VS840 4G using Mustang Evolution mobile app
Jared Witmer is offline   Reply With Quote
Old 08-11-2015, 07:43 PM   #3
G1994T's Avatar
Where is everyone?!
Old 08-12-2015, 12:36 PM   #4
smurf stang's Avatar
Check your codes first....
http://sbftech.com/index.php/topic,2471.0.html
Here is what they mean....
http://sbftech.com/index.php?PHPSESSID=7261a4935687afe79b81c982b1b049ec&/topic,849.0.html
Then do a base idle reset.....
http://sbftech.com/index.php/topic,1031
Also check for vacuum leaks.
When was the last time you did a full tune?
2016 VW GTI 2.0 Turbo
Old 08-12-2015, 12:58 PM   #5
Clean the MAF element with MAF cleaner, to the fuel filter, very well could be time for new injectors. Should have seen the ones I pulled out of my 95 Cobra back in 2007 and those only had 60k on them...
Old 08-13-2015, 08:03 PM   #6
G1994T's Avatar
Ok all fixed. But there's a chirping sound for about five minutes after I start it. What's this?
Old 08-13-2015, 09:49 PM   #7
If it goes away when you push in the clutch its probably the throwout bearing. Either needs adjusting or it is going bad. Also could be as simple as a pulley or tensioner.
Old 08-13-2015, 09:55 PM   #8
So what was it, what cured the problem so future generations can fix their problems also.
Sent from the Bathroom
Old 08-14-2015, 01:17 PM   #9
G1994T's Avatar
It was the throttle body. I cleaned it but when I put it back together I didn't do it right so I had my mechanic do it. I don't have a lot of space to work on the car because I live in New York City so it's easier just to have someone do it. I try to do things I don't need a lift or a driveway for but I'm not very good at it!! 😳
Old 08-14-2015, 02:41 PM   #10
dwbrand's Avatar
That's how you get better: you try and you learn from it 👍🏻
2003 Ford Mustang GT
1995 Ford F150 XLT 4x4
1968 Mercury Cougar
dwbrand is offline   Reply With Quote
Old 08-14-2015, 07:35 PM   #11
wbrockstar's Avatar
I see you finally made it over to sbftech SmurfStang.No site will teach you how to trouble shoot the Foxbodys EEC-IV system like that place will.Joel is a genius at that stuff and Woody's got the engine side covered to a t,don't ya think??Not discrediting this place at all,but those two guys can explain trouble shooting methods forwards,backwards and in anybody's language.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 08-14-2015, 08:14 PM   #12
Woody is hands down the only person I'd ever trust to build a SBF. Well I mean his shop Fordstrokers. I wish he'd do modulars but that'll never happen while ppl are beating his proverbial door down for small blocks. IIRC his waitlist is 2 months from the time you order to the time he begins work on your motor.
Old 08-14-2015, 10:08 PM   #13
wbrockstar's Avatar
Even though a businesses main goal is to primarily make money,Woody seems like he's in it more so to make people happy and to provide a product that will give you 100,000+ dependable miles on the street and/or 100's of passes down the track.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
Old 08-14-2015, 10:51 PM   #14
Shifty 5.0's Avatar
Yeah woody is good and his wait is long! Lol I know a lot of people that have bought blueprint stroker motors and they make good power with a good warranty
Shifty 5.0 is offline   Reply With Quote
Old 08-17-2015, 10:54 AM   #15
Been there for years just don't post as much over there. Knowledge over there is great. I come here to
rpms dropping for no reason Robbiemustang96 Pre-2005 V6 Mustang 8 09-24-2012 10:57 PM
rpms dropping Robbiemustang96 Pre-2005 V6 Mustang 2 08-28-2012 10:23 PM
Window Control Panel in Door - Dropping/Moving SarasotaTim 1996-2004 Mustang GT 6 07-23-2010 07:49 AM
Deadly Bird Dropping: MarkuzLS1 Mustang Audio & Video 15 05-24-2006 07:39 AM
holy jaw dropping fox!! Zim The Bar 19 10-29-2005 08:04 PM
01:37 PM
