What to look for when buying a fox body - Page 2 - Mustang Evolution
Old 08-13-2015, 08:02 PM   #36
alterego's Avatar
tranny is different, its a hydraulic clutch. you will have to deal with that
alterego is offline   Reply With Quote
Old 08-13-2015, 09:50 PM   #37
Originally Posted by smsstang View Post
So the 4.6 is a better motor to modd than the original 5.0 ? And everything will drop right in like the engine,tranny,rear end ?
If you have a donor car then yes.
No. Those started in 05.
Old 08-14-2015, 04:20 AM   #38
alterego's Avatar
My sister had a 98, I wanted to do some things with it an the t5 was the reason I forgot about it. It's been years ago but I know they changed in 94. Look at this link... http://www.pro-forceperformance.com/t-5_interchange.htm
Old 08-14-2015, 05:11 AM   #39
All Mustangs till 05 had cable clutches unless someone installed an aftermarket unit. Also unless it was a V6 it didn't have a T5.
Old 08-17-2015, 09:57 PM   #40
smsstang's Avatar
Okay found a 89 lx 5.0 and for a pretty good price .. The cons I noticed . It's kinda hard to get into first gear and reverse kicks out sometimes ? On the engine the owner said there is vac leaks he sais he fixed some big there are some left ? Noticed when driving when you punch it in first and second it feels like it's sucking to much air putting a drag it feels like .. And how can you tell if it's an original motor ? I have pics to show ? But other than that I checked the underside all over the body and fenders and car is really straight ?
smsstang is offline   Reply With Quote
Old 08-18-2015, 06:56 AM   #41
I'm not trying to be an ***... but you really should make friends with someone who knows these cars before you buy a fox that needs work. That one you are describing right now sounds like a money pit.
Transmission is likely going to have to be rebuilt as far as the gear issues. It will have to come out of the car at a very minimum for clutch work.
Old 08-18-2015, 08:39 AM   #42
smsstang's Avatar
Well Scotty considering I want it to be a build project and knowing that I'm gonna spend money that does t bother me .. And the car price as of now after talking with the guy stands at 2500$ ? That's not a bad price to start out with is it not ?
Old 08-18-2015, 10:09 AM   #43
If the frame is straight and no rust... I'd try to get it closer to $1500 if the motor and trans are messed up.
Old 08-18-2015, 11:42 AM   #44
smsstang's Avatar
Yeah the frame is really straight and there is no rust underneath or on body the only place with rust and it's just surface rust in right in front of the windshield where the panels are .. And in the engine if I where to take it out and inspect it can't I just bore it out ? Or is that bad to do ?
Old 08-18-2015, 11:57 AM   #45
alterego's Avatar
Tell the guy to keep his engine and tranny and give him $800 for the rest
Old 08-18-2015, 12:14 PM   #46
smsstang's Avatar
I wish it was that easy ... All in all if the tranny and motor turn out to be a peace of .... Then we can start from scratch . I'm mainly just looking how the frame and body is .
Old 08-18-2015, 10:18 PM   #47
Then find a clean 4 banger some old person drove for 25 years and garaged and is low miles. I just saw one near me with a blown trans and mint condition (and blue interior bleh) sell for $1100 near me. 40k miles and the exterior was a solid 9/10.
Old 09-03-2015, 06:14 AM   #48
Hey guys i am looking at a 1990 mustang 5.0 that has a 347 stroker in it. I know it wont be the greatest on gas but i am curious if it would make over 10mpg and would be okay to drive everyday. I dont drive much mainly to work and back and work is 25 minutes away. There are other things done to it of course but these are the things he listed
The mods are:
1989 Ford Mustang gt
Motor
347 stroker
Edlebrock estreet heads
Roller rockers
X cam
Edlebrock typhoon intake
Bbk cold air
Precision products throttle body
Ford racing valve covers
Canton deep oil pan
T5 transmission
New king cobra clutch
B&m short throw shifter
Aluminum drive shaft
Front kyb struts with coilovers
Rear Kyb shocks
Rear lowering springs
Tubular upper and lower rear control arms
Weld on sub frame connectors
colebartakovic is offline   Reply With Quote
Old 09-03-2015, 06:15 AM   #49
Sorry it is a 1989 not a 1990
Old 09-03-2015, 06:45 AM   #50
alterego's Avatar
How is it geared in the *** end? I have a 90 it's 3:73 and I think it would do 12mpg. But still it's all how you act in it. My coyote has seen 8mpg often.
Old 09-03-2015, 06:55 AM   #51
Im not to sure on the gearing i will have to ask him
Old 09-03-2015, 05:54 PM   #52
smurf stang's Avatar
What size injectors, MAF, headers and throttle body?
Does it have AC?
Pictures....
Small heads and intake for a stroker,
2016 VW GTI 2.0 Turbo
Old 09-03-2015, 07:03 PM   #53
Titus Wadicus
svtlx's Avatar
if anyone here is serious about doing a swap please feel free to pm me. i can give you a list of do's and dont's. ive done a '89 3.8 tbird to 5.0 efi.. 93 notch 4cyl to 5.0 efi (s/c)... 96' stang 3.8 to 5.0 efi (s/c).... and currently a '00 stang 3.8 to 5.8 efi (s/c) a poor mans saleen 351... however, when your serious... its a big list
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 09-03-2015, 07:59 PM   #54
It has 24lb injectors, dont know the maf it has a 70mm throttle body and its running shorty headers
---------- Post added at 01:59 AM ---------- Previous post was at 01:59 AM ----------
And it has no a/c
Old 09-03-2015, 09:12 PM   #55
Name:	ImageUploadedByMustang Evolution1441336022.548829.jpg
ID:	190562Click image for larger version
Name:	ImageUploadedByMustang Evolution1441336041.090912.jpg
ID:	190563Click image for larger version
Name:	ImageUploadedByMustang Evolution1441336052.877025.jpg
ID:	190564Click image for larger version
Name:	ImageUploadedByMustang Evolution1441336068.568510.jpg
ID:	190565Click image for larger version
Name:	ImageUploadedByMustang Evolution1441336085.410031.jpg
ID:	190566Click image for larger version
Name:	ImageUploadedByMustang Evolution1441336097.400661.jpg
ID:	190567Click image for larger version
Name:	ImageUploadedByMustang Evolution1441336199.234553.jpg
ID:	190568Click image for larger version
Name:	ImageUploadedByMustang Evolution1441336215.690561.jpg
ID:	190569Click image for larger version
Name:	ImageUploadedByMustang Evolution1441336230.014602.jpg
ID:	190570Click image for larger version
Name:	ImageUploadedByMustang Evolution1441336248.906540.jpg
ID:	190571Click image for larger version
Name:	ImageUploadedByMustang Evolution1441336263.182129.jpg
ID:	190572Click image for larger version
Name:	ImageUploadedByMustang Evolution1441336279.324104.jpg
ID:	190573Click image for larger version
Name:	ImageUploadedByMustang Evolution1441336293.263927.jpg
ID:	190574Click image for larger version
Name:	ImageUploadedByMustang Evolution1441336311.420735.jpg
Those are some of the pictures of it
Old 09-04-2015, 01:55 PM   #56
The only thing I will say is that good deals on clean foxes do not last this long. Either something is up or he is asking too much.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 09-04-2015, 03:40 PM   #57
Well it just sold i was going to go look at it today and someone came and bought it 2 hours before i was. Since im still looking for a car i was curious of which car would be faster and better.
A fox with a cold air intake, 3.73 gears, new clutch, and lowered.
Or a 1990 305 camaro with a hurst short shifter, new clutch, cat back, new injectors, spark plugs, spark plug wires.
Old 09-04-2015, 04:02 PM   #58
alterego's Avatar
Mustang!!
Old 09-04-2015, 04:09 PM   #59
Mustang!!
Yeah i was leaning more towards the mustang
Old 09-04-2015, 04:42 PM   #60
Friends don't let friends drive 305s
Old 09-04-2015, 04:45 PM   #61
alterego's Avatar
Name:   ImageUploadedByMustang Evolution1441406709.444869.jpg
Old 09-04-2015, 06:06 PM   #62
RoCoBass's Avatar
Region: Iowa
As described, faster... Camaro, be realistic people! Better looking the Fox.
Sent from my XT1526 using Mustang Evolution mobile app
RoCoBass is offline   Reply With Quote
Old 09-06-2015, 08:07 PM   #63
wbrockstar's Avatar
Here's a write-up that shows the Coyote to Fox swap.This was done by Mustangs & Fast Fords Magazine.The car shown was a 4 cylinder car to start with,got swapped to a 5.0 then swapped again for the Coyote.
How to Install a 5.0 Coyote Into a Fox Mustang - Breeding Easy
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 09-08-2015, 09:55 AM   #64
Big DaddyO's Avatar
Look for a good solid Foxbody GT version with Manual Transmission. Most LX versions had automatic transmissions. The manual trans equipped models appreciate much better. Also, try to find a factory T-Top of Sunroof version. Although, not a rare option, but not may still exist with a good fit.
Big DaddyO is offline   Reply With Quote
Old 09-08-2015, 09:58 AM   #65
alterego's Avatar
I had an 88 t top. Liked the top but gah that car would twist. I actually slung one of the tops out in a hard pull. Amazingly thou it did not break.
Old 09-08-2015, 12:39 PM   #66
If you want a fox you find the cleanest fox you can. Period.
Very often this is a 4 banger automatic in some old person's garage that has like 70k miles on it and has been driven 3 times a week for 25 years to the Supermarket, Bingo and maybe Church.
And who the hell cares if its an auto 4 banger? Foxes are so easy to work on and so swappable it isn't even funny. I'll take a very clean 4 banger auto with a red or blue interior and no rust and decent paint over some "clean" 5.0 that has been through who the hell knows what any day.
Old 09-12-2015, 11:01 PM   #67
So every foxbody i want to get sells before i could go get it which i get because they are all so nice. I am looking at another one that hasnt been updated on craigslist but i have talked to the guy and he isnt going to update it so i actually have time to go look at it. The only problem is he knows nothing about it, he told me the only thing he knows that the owner before him which was a mechanic said that the engine is bigger than a 5.0, has a full exhaust from the headers back and has a short shifter. Thats not to much to go off of and im worried about it.
I'm selling a red ford fox body mustang 5.0 for 8000$ firm there's a rebuilt custom engine In it with only 17,000 km.on the original odometer there's like 142,000 km.400hp at the wheels.-e303 cam ported and polished heads,after market headers upgraded injectors straight dual exhaust cat and resonator delete flow master mufflers. I have the original seats as we'll
-no accident
-hatchback
-5speed
This is what the add sais but when i ask him questions he doesnt mention anything about those things that have been done to the car. I saw pictures of the outside and it looks really nice and ive seen the engine and interior at local car meets and its a really nice car just alot of unknowns. Do you guys think it would be worth it?
Old 09-14-2015, 01:26 PM   #68
$8,000 is a bit tough.....specially if the guy doesn't know anything about the car. All that stuff you can't see that is "supposedly" done to the car is also tough to validate without receipts. And even with receipts take it with a grain of salt.
Old 09-14-2015, 01:43 PM   #69
Yeah well it is 7300 now and i can definatly talk him down because of all the unknowns. I was just thinking the only way to tell if it does have anything is by hearing it idle to see if it actually does have a cam, then test driving it and putting it to the floor to see how fast it really is and then putting it on a dyno because if it is bigger than a 5.0 alot of people usually do 306 builds and it should have more than 320rwhp if its done right
Old 09-15-2015, 07:39 AM   #70
A vacuum leak will sound like a cam.
The only way he will let you slap it on a dyno is after you have paid him and it's your to beat and romp on.
Thirdly a 306 is just a bored out freshened 302. It can be a stock rebuild meaning it has 225 hp to the crank or it can be a high end rebuild with high compression pistons, lightweight rods, tight tolerances and all types of internal tricks to squeeze more hp. All of this will be an unknown unless you open the motor. Them's the breaks.
fox body
Body kit on Fox body MustangMitch50 1979-1995 Mustang GT 3 09-18-2014 08:23 AM
cheap fox body body panels Jonnyfast89 General Car Discussion 2 04-22-2011 03:02 PM
v6 to true exaust. buying parts. am i buying the right parts steveyb927 Pre-2005 V6 Mustang 4 04-16-2009 10:04 PM
What should I look for when buying a 67 stang Justin-Heath Classic Mustangs 4 12-05-2006 10:17 PM
Body Kits, Body Kits, Body Kits! *DUW* *WW* Dom Mustang Audio & Video 75 02-01-2004 07:11 PM
11:12 PM
