Air.injection hose diagram? - Mustang Evolution
Old 08-17-2015, 01:35 AM   #1
95gtnewb's Avatar
Does anybody have e air injection hose diagrams? I think I'm missing something and I don't know where it connects to....
Sent from my XT1031 using Mustang Evolution mobile app
95gtnewb is offline   Reply With Quote
Old 08-18-2015, 08:08 AM   #2
wbrockstar's Avatar
Is this what you're looking for or is the 94-95 system different??
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 08-18-2015, 08:29 AM   #3
IIRC its the same for the SN95 and the Fox or at least so similar he will be able to figure it out. I just trashed the entire thing.
Old 08-18-2015, 01:20 PM   #4
95gtnewb's Avatar
Yea that's a good one. Thanks. I'm missing a part and can't figure out what it's called
---------- Post added at 07:20 PM ---------- Previous post was at 07:19 PM ----------
Thanks guys much appreciated
Old 08-18-2015, 04:12 PM   #5
wbrockstar's Avatar
Glad to help.I agree this stuff can be trashed,if converters aren't being used.However if they are being used,the thermactor system components have to be used,otherwise the converters will clog & fail.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
Old 08-18-2015, 08:53 PM   #6
Nah, just run a pipe to the cats directly from the smog pump. I would not run cats on a 95-down car because of all the ridiculous bull**** that attaches to them. Trashed this crap, plugged the heads after removing the crossover, G2G. Swapped in the stock pipe every 2 years for emissions.
Old 08-19-2015, 09:07 PM   #7
wbrockstar's Avatar
Yeah that's another good way to do it.I assume a emissions testing station just checks to make sure the cel isn't on and converters are in place,right??If the cel/mil isn't on,its considered passing,as far as the visual inspection goes.They don't actually check the ecm to make sure no codes are present,right??Removing the thermactor components will cause trouble codes to be stored,but these codes won't trigger a cel/mil and they also won't cause any driveability issues.
Running a long hose from the smog pump to the converters will have the same effect as keeping everything in place,but without the clutter.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
Vacuum hose diagram romeshs1983 2011-2014 V6 Mustang 5 09-26-2013 12:43 AM
Vacume hose diagram? sixpac 1979-1995 Mustang GT 10 06-02-2012 09:49 PM
Secondary Air Injection System Monitor Circuit Low Voltage BruThru2002 Pre-2005 V6 Mustang 6 03-23-2011 04:02 PM
With or Without Air Injection TBone Pre-2005 V6 Mustang 7 08-14-2005 03:59 AM
Secondary Air Injection blah blah blah BruThru2002 Pre-2005 V6 Mustang 3 07-14-2004 10:18 PM
03:48 PM
