Tune up - Mustang Evolution
Old 08-18-2015, 06:15 PM   #1
209stang's Avatar
Tune up
What do I need for a tune up for my FOXBODY all I've done was oil changes and brakes since I got it. I have new spark plug wires rotor cap oil and oil filter. What else should I get that will help me for the long run? Thanks
209stang is offline   Reply With Quote
Old 08-18-2015, 08:45 PM   #2
havhammer's Avatar
Fuel filter, pcv screen at the back of the intake should be checked. New spark plugs and maybe check the timing.
Sent from my SPH-L710 using Mustang Evolution mobile app
havhammer is offline   Reply With Quote
Old 08-19-2015, 09:20 PM   #3
wbrockstar's Avatar
I agree.Check the timing and adjust it to 10-14°,if using high octane fuel.87 octane can be used if its set to 10°,but use high test if going up to 14°.The 10 pin maintenance procedure is a good thing to do while you're at it,to prevent future issues.Check & replace any vacuum hoses that need attention.I like running Royal Purple synthetic in my transmission(if its a T5) and differential.It really seems to help in the winter with easier shifting when the transmission is cold.Clean throttle body(if dirty)& replace pcv valve.
Fuel Injection Technical Library » 10-pin Connector Fix
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 08-21-2015, 03:34 PM   #4
209stang's Avatar
I got royal purple synchro max high performance manual transmission fluid.
Old 08-22-2015, 06:43 PM   #5
209stang's Avatar
Does anyone know if that's the proper transmission fluid I should go with?
Old 08-22-2015, 07:09 PM   #6
smurf stang's Avatar
The T5 is not really a finiky transmission so clean ATF and regular flushes. If purchased used then it's a crap shoot.
Sent from the Bathroom
2016 VW GTI 2.0 Turbo
Old 08-22-2015, 07:46 PM   #7
havhammer's Avatar
Yes the syncromax is the correct royal purple product for the t-5.
Old 08-24-2015, 07:50 AM   #8
I always used Dex/Merc III in T-5s with great results. They're really simple transmissions with THE smoothest action of any trans ever pretty much.
Old 08-24-2015, 11:11 AM   #9
True.
hybrid tune vs. race tune 13 stang22 2011-2014 V6 Mustang 37 03-30-2013 08:38 PM
to tune or not to tune.... rebeltx 2011-2014 V6 Mustang 24 01-02-2013 10:46 AM
Bama tune or lund tune or steeda tune Mustang32Bill 2011-2014 Mustang GT 89 11-12-2012 10:45 AM
Question on installing Bama tune if previous tune already loaded on car ljn21 2011-2014 Mustang GT 7 08-01-2012 10:08 AM
To tune or not to tune? grossnickle6612 2011-2014 V6 Mustang 10 08-24-2011 09:27 PM
11:48 PM
