Low coolant - Mustang Evolution
Old 08-25-2015, 04:45 PM   #1
209stang's Avatar
Low coolant
Does anyone know why my low coolant light is always on? Maybe a week after I put new coolant. And the radiator is always low with the coolant
209stang is offline   Reply With Quote
Old 08-25-2015, 05:22 PM   #2
ebourd's Avatar
Maybe a bad sensor or wiring
---------- Post added at 04:22 PM ---------- Previous post was at 04:21 PM ----------
Also what year make and model you got will help people help you
ebourd is offline   Reply With Quote
Old 08-26-2015, 11:40 AM   #3
smurf stang's Avatar
So OP you are saying your rad is always low on coolant?
Well the cooling system is a closed unit so the only way for coolant to be lost/escape is by being burnt off or dripped/leaked out.
2016 VW GTI 2.0 Turbo
Old 08-28-2015, 07:52 PM   #4
wbrockstar's Avatar
I agree with SmurfStang.You might wanna trouble shoot while you're constantly losing coolant.If external leaks aren't present,the lower intake gasket,head gasket or heater core is probably leaking.Head gasket usually causes steamy smoke from tailpipes,wet spark plugs at two adjacent cylinders,oil looks like it has a milkshake mixed in with it,overheating and detonation (sometimes)A leaking intake gasket usually causes the same milkshake appearing oil,but not overheating (unless coolant level gets too low)
If the coolant gets below a certain level in the coolant recovery bottle,the low coolant light will come on.If the level is above the min-max mark on the bottle & the light is still on,the low coolant sensor needs to be replaced. Its about $75 bucks though.Looks like the part below
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 09-02-2015, 10:02 AM   #5
So OP did you check it out?
Low engine coolant? Chaz12 2011-2014 V6 Mustang 0 03-25-2015 12:29 PM
93 gt low coolant Fballman9 1979-1995 Mustang GT 3 09-11-2013 04:26 AM
Low coolant light staying on 35th GT 1996-2004 Mustang GT 12 03-10-2013 02:09 PM
Low coolant light captain78 1979-1995 Mustang GT 7 01-02-2012 08:05 PM
06:06 PM
