1987-1993 Foxbodies - Mustang Evolution
Old 08-28-2015, 11:21 PM   #1
5pointYoBro's Avatar
1987-1993 Foxbodies
Going to look at a 1990 hatchback 5.0 tomorrow.
98,000 miles
I know most things to look for, leaking fluid, engine noise, trans slippage.
What are common things that go bad with these 87-93 foxbodies??
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 08-30-2015, 09:37 AM   #2
Foxbody91's Avatar
Always check motor mounts and strut towers
Foxbody91 is offline   Reply With Quote
Old 09-02-2015, 10:07 AM   #3
smurf stang's Avatar
Read this..........
Buying a Fox body Mustang: What to look for when purchasing a Fox
2016 VW GTI 2.0 Turbo
Old 09-02-2015, 10:57 AM   #4
RoCoBass's Avatar
Region: Iowa
So what was the outcome Lava? Patience is key when trying to get a good Foxbody
Sent from my XT1526 using Mustang Evolution mobile app
RoCoBass is offline   Reply With Quote
Old 09-02-2015, 08:01 PM   #5
Was a complete bust....
The first day I went to look at her it fired up good right away and drove nice, trans was good.
Then the next morning me and my dad went back, started it up and it died. Started it again and it idled really weird. Sounded like it had a cam and wanted to die. I also saw the check engine light come on and off.
This was a fuel injected 5.0 so I shouldn't have needed to warm up right???
Once it idled for about 5 minutes it sounded right, then out of no where started leaking coolant out of the radiator cap lol.
Old 09-02-2015, 08:18 PM   #6
alterego's Avatar
That old AOD tranny was ****
alterego is offline   Reply With Quote
Old 09-03-2015, 08:23 AM   #7
This one had a t-45 in it.
And I dont think it had the original motor
Old 09-03-2015, 08:48 AM   #8
alterego's Avatar
Because you mentioned checking trans slippage I guess I assumed it was an auto.
Old 09-03-2015, 05:56 PM   #9
I couldn't have had a T45 with the 5.0 motor.
It took me months and driving 12 hours away till I settle on a suitable fox.
Old 09-03-2015, 07:23 PM   #10
alterego's Avatar
I figure it's a t5
Old 09-03-2015, 10:50 PM   #11
^^^ thats what I meant, my b
Old 09-04-2015, 05:09 PM   #12
No worries just keep a good eye, don't get desperate and be patient.
Sent from the Bathroom
Old 09-04-2015, 07:42 PM   #13
Yeah I've made that mistake before on a Pontiac sunfire.
I'm looking at new edges too
Old 09-04-2015, 11:03 PM   #14
Shifty 5.0's Avatar
Yeah I went fox hunting for awhile and finally found this gem at a dealership Click image for larger version
Name:	ImageUploadedByMustang Evolution1441429332.160964.jpg
ID:	190676 it was all stock besides a cam and now makes over 500 to the wheels and is far from stock
Shifty 5.0 is offline   Reply With Quote
Old 09-05-2015, 05:21 AM   #15
BossDrew's Avatar
Region: West Virgina
500 hsp by just changing out the cam?!? Where do I sign up?
_______________________________________
1990 LX Convertible / 25th Anniversary
BossDrew is offline   Reply With Quote
Old 09-05-2015, 05:52 AM   #16
alterego's Avatar
White hoods add 100% more hp
Old 09-05-2015, 09:49 AM   #17
Shifty 5.0's Avatar
That's why I said WAS (in the past)all stock besides a cam and NOW (as in the present) is far from what is was lol
Old 09-05-2015, 09:55 AM   #18
Shifty 5.0's Avatar
Name:	ImageUploadedByMustang Evolution1441468444.310343.jpg
There she is nowClick image for larger version
Name:	ImageUploadedByMustang Evolution1441468486.058287.jpg
ID:	190691Click image for larger version
Old 09-05-2015, 10:23 AM   #19
alterego's Avatar
Woopse I meant what's under the white hood adds 100% hp.
Old 09-06-2015, 05:41 AM   #20
Varasios's Avatar
Looks awesome smurf
Varasios is offline   Reply With Quote
Old 09-06-2015, 07:27 PM   #21
wbrockstar's Avatar
That's definitely not a OEM color/finish is it Shifty??Good color choice.Now all you gotta do is get the charger,upper intake,PS pump & tensioner pulley polished to make the inside look as good as the outside does.BTW-are the engine parts painted or powder coated??Kinda look like they're coated.I was asking because I done that kind of work before at Advanced Plating in Nashvegas
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 09-06-2015, 09:23 PM   #22
^^^ Hello fellow Tennessean! I've never seen anyone on here from Nashville.
On another note,
Are the AOD 4 speed transmissions really that bad???
Old 09-06-2015, 10:26 PM   #23
Shifty 5.0's Avatar
The car color is sonic blue and no they're not powder coated. I just stripped the previous paint/primer/ then high temp paint
Old 09-07-2015, 08:54 AM   #24
Varasios's Avatar
Lol *shifty
My bad
Old 09-08-2015, 09:51 AM   #25
Big DaddyO's Avatar
Look at the window seals around the rear quarter panel. Usually, these can be cracked or brittle. Not a tough fix if you buy aftermarket replacement windows. You can opt for an overlay trim. The replica windows will not have the Mustang name etched.
Big DaddyO is offline   Reply With Quote
Old 09-10-2015, 01:57 PM   #26
Here is my labor of love.
ID:	190934   Click image for larger version
Old 09-10-2015, 02:00 PM   #27
Money started to run out by the end so I had to reuse the 1-5/8" headers and other stuff.
ID:	190937   Click image for larger version
Old 09-10-2015, 05:17 PM   #28
Varasios's Avatar
Looks very nice 👍
Old 09-11-2015, 12:57 PM   #29
Man that baby is clean! Is your engine board over to 349?
Old 09-11-2015, 02:31 PM   #30
alterego's Avatar
I can't see the pic 😢
Old 09-14-2015, 01:22 PM   #31
Yeah it was a stroker kit and bored over .040".
Old 09-18-2015, 10:01 PM   #32
wbrockstar's Avatar
Looks real nice Smurf,especially those big *** longtubes.Did you go from a stock bore (4.000") straight to the (4.040") bore or was the block already bored (4.030") and you went to a (4.040") bore from there??Have you experienced higher engine temps since moving to a (4.040") bore??I'm only asking out of curiosity because a (4.060") block usually runs on the hot side due to the thin cylinder walls.I'm curious if the same issue has popped up or not,considering thats only(.020") away from the non usable block which overheats.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
Old 09-20-2015, 09:51 PM   #33
Not really hotter. Running AC in Miami and I cruise anywhere, the hottest it has run was 208. Driven it to Bradenton and down to the Keys with no problems.
Who out there has 4eyed foxbodies? Jared Witmer 1979-1995 Mustang GT 5 08-05-2015 10:48 AM
Are there any shelby foxbodies? Haav 1979-1995 Mustang GT 6 07-21-2012 01:31 PM
foxbodies on steel wheels SmokedLX 1979-1995 Mustang GT 2 06-04-2012 10:50 PM
Would a 1987-1993 ford mustang 5.0L AOD tranny fit a 1995 ford mustang 5.0L engine? raimondo General Mustang Discussion 1 03-14-2010 01:37 AM
Foxbodies> * bullitt482 The Bar 113 06-12-2007 07:49 AM
10:40 PM
