82 5.0 won't fire - Mustang Evolution
Old 09-12-2015, 09:29 PM   #1
82 5.0 won't fire
I have a 1982 Ford Mustang GT 5.0 with a Street avenger Holley carb 670 cm.
I recently was rewiring the mess the last "mechanic" was doing and then it just stopped starting. I check the ignition wiring from alternator all the way to the ignition switch to the carb etc. I just replaced the ignition coil, ignition coil connectors, cap, rotor and all fuses. It will crank and crank strong but it will not fire up. The fuel filter fills up with fuel so I don't suspect the pump to be bad and I can see the fuel squirt into the carb itself. Any ideas or suggestions will help greatly.
I bought the Manuel but the diagram doesn't match up to well to my mess
Wombatnation is offline   Reply With Quote
Old 09-13-2015, 11:01 AM   #2
wbrockstar's Avatar
If it was running before you began messing with the wiring,its probably something electrical.The link below shows some great trouble shooting steps for the Duraspark l,ll, & lll ignition system.After you open the link and view its information related to the ignition,if you wanna view wiring diagrams for your model,do this.Click on select a chapter,click on chassis electrical,click on wiring diagrams then scroll down til you see your year model listed.Follow this same procedure if you wanna search other systems like engine electrical,suspension,etc.
http://www.autozone.com/repairinfo/r...00c1528004dd0c
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 09-13-2015, 01:37 PM   #3
| Repair Guides | Electronic Ignition Systems | Diagnosis And Testing | AutoZone.com
this is the reason you replace one wire at a time,do you have 12 volts to positive side of coil? If not look for wire thats hot with key on jump it to positive side of coil. don't do this back off for thirty minutes then start checking everything
ALLYDRIVER1 is offline   Reply With Quote
2000 V-6 Cranks but won't fire jbow Pre-2005 V6 Mustang 2 12-25-2014 09:21 AM
Dashes across odometer, car won't fire up - Not looking good. V6 stang Pre-2005 V6 Mustang 9 07-29-2012 09:59 PM
68 coupe 289 lights come on but won't turn over and headlights won't come on Sixty8 Coupe Classic Mustangs 2 03-07-2009 07:52 PM
O'Reilly under fire damustangfan14 The Bar 10 10-15-2004 12:17 AM
07:08 AM
