Clutch pedal. - Mustang Evolution
Old 09-23-2015, 06:21 PM   #1
209stang's Avatar
Clutch pedal.
What can I do to fix my clutch pedal it's very sensitive and I have to push to floor to change gears? Please help
209stang is offline   Reply With Quote
Old 09-23-2015, 06:27 PM   #2
have you adjusted it? simple catch pedal and pull up you will hear click may have to do several times
ALLYDRIVER1 is offline   Reply With Quote
Old 09-23-2015, 06:40 PM   #3
209stang's Avatar
Yeah the shop said I need a new clutch cable.
Old 09-23-2015, 08:38 PM   #4
smurf stang's Avatar
How did they come to that conclusion?
Try what was said above if you have a stock quadrant. Pull up on it till you hear it click.
What kinda clutch do you have? Quadrant? Adjuster? Cable?
2016 VW GTI 2.0 Turbo
Old 09-24-2015, 04:39 AM   #5
209stang's Avatar
Adjustable
Old 09-24-2015, 01:19 PM   #6
Adjustable what? Adjustable cables are garbage as are all aftermarket ones. Replace with a stock OEM cable, a MM quadrant and a fiore micro click firewall adjuster and never have cable problems again.
Old 09-25-2015, 10:39 AM   #7
Adjustable
Well ooooookkkkkkaaaaayyyyy.........adjustable what?
Try to give as much information to get the best answer. The more questions we have to ask the longer it will take to fix your problem.
Clutch Pedal Height Adjustment and Clutch Freeplay Mod ab_mach1 1996-2004 Mustang GT 126 10-20-2017 03:21 AM
Shaking clutch pedal until pedal is pushed GHO5T5NIPER 1996-2004 Mustang GT 78 05-03-2015 11:47 PM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
Look its fast64's clutch pedal assembly steedav6builder The Bar 14 04-09-2005 10:35 PM
clutch pedal sags? tedness Pre-2005 V6 Mustang 4 03-19-2005 11:10 AM
06:21 PM
