1990 Ford Mustang 5.0 - Mustang Evolution
Old 10-01-2015, 05:16 PM   #1
I have a 90 foxbody and it was wroking good
The car had been setting for a couple of years and I turned it on yesterday and everything worked
I turned it off and came back outside tried to turn it on and I wouldn't start
I checked the gas and it has gas
I replaced the fuel filter and it still won't start
I'm guessing it's the fuel pump anybody have any ideas?
Josueb8 is offline   Reply With Quote
Old 10-01-2015, 06:01 PM   #2
Try spraying some starter fluid down the throttle body. If it tries to start, or at least pops, then you likely have a fuel problem. If it still does nothing, using the starter fluid, then there is probably no spark.
This will at least narrow the diagnosis process down a bit.
Old 10-02-2015, 01:09 PM   #3
smurf stang's Avatar
You can usually hear the fuel pump working........can you hear yours prime?
2016 VW GTI 2.0 Turbo
Old 10-16-2015, 01:44 PM   #4
wbrockstar's Avatar
When a efi equipped car sits for years,it can cause injector issues.One,or more,of the injectors could be leaking internally due to the varnish that builds up on them while sitting.If you drive the car til it reaches operating temp then turn the engine off & attempt a restart a few minutes later,a no start can sometimes indicate the fuel pressure regulator is defective or a injector(s)is leaking internally.If you turn the engine off and immediately check static fuel pressure then check it again after 60 seconds,pressure should Not drop more than 5psi in that 60 second time period.If it does drop more than that,a injector(s)is leaking, the fpr is defective or there's a leak in the fuel hose between the pump & fuel pump pickup or the pump relief valve.If this pressure bleed off is occurring,you can remove each spark plug & see if its wet with fuel.If it is,that cylinders injector is leaking.To check the regulator,let the engine reach operating temp,let it idle,remove the vacuum hose from the fpr.Is there fuel inside of the hose or is fuel seeping out of the regulator vacuum port?If yes,the fpr is bad.Another check to do is this::when the hot no start condition is present,hold the gas pedal to the floor while you try starting the car.If the car starts after a few seconds,that's another indication for a leaking injector.When the pedal is floored during cranking,that shuts the injectors off to clear a engine flood condition, so the engine starting is your sign there's too much fuel entering the cylinder(s) so an injector(s)must be leaking.
StrayBullitt's post mentioned doing the starting fluid trick,which is also a good test.Just remove the breather tube(between the oil filler neck on valve cover & the throttle body)from the throttle body,spray starting fluid or carb cleaner into that opening on the TB,reattach tube,attempt a startup.If the car starts & runs for a few seconds then dies,you've got a No Fuel problem.If it doesn't start at all,you've got a No Spark problem.
Another common cause for a hot no start is a defective pip sensor or TFI module.Let me know if you wanna test them & I'll post the testing procedure link for both sensors.Be sure to do the maintenance procedure on the salt & pepper shakers too.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Mustang :: 1990 Ford Mustang crroy71 Member Garages 0 03-17-2014 05:40 AM
Can u put a 1993 ford mustang starter in a 1990 mustang? sydeek 1979-1995 Mustang GT 4 12-16-2011 09:14 PM
Mustang GT Cobra :: 1990 Ford Mustang GT Cobra mustangcobra90 Member Garages 0 07-23-2011 09:14 AM
Can I fit everything in a 1990 ford mustang 5.0 to a 1953 ford F-100? redvers General Mustang Discussion 6 03-06-2010 01:07 PM
01:49 AM
