Help - Mustang Evolution
Old 10-14-2015, 05:13 PM   #1
Help
Rear end movement
Sent from my A0001 using Mustang Evolution mobile app
thomass7784 is offline   Reply With Quote
Old 10-14-2015, 05:14 PM   #2
I have a 1994 mustang gt clone and the rear end feels like it it swaying side to side
Old 10-14-2015, 05:17 PM   #3
Voglen springs and new tubular arms what could it be I have wide tires on the rear also
---------- Post added at 11:17 PM ---------- Previous post was at 11:17 PM ----------
The widest you can go
Old 10-14-2015, 05:22 PM   #4
Both the upper and lower control arms have been replaced?
Old 10-14-2015, 06:16 PM   #5
Yes it has 275/40/17 on the rear with 1/4 inch spacers it feels like the rear end moves and I have to stear to correct it it almost feels like its floating its lowered also with volglen spring I know that isn't spelled right but it did all this before I did the mods uppers and lowers have been replaced tubular came with new bushing already pressed I read some where it might be the wide tires do you think a panhard bar might help its been doing these sence I owned it even as a v6 I did all the conversion myself including the rear end it did this even with the old v6 rear end everything's been replaced idk what it could be
Old 10-14-2015, 06:18 PM   #6
It feels like the rear end floats it dosnt eat tires or anything when I hit bumbs the rear end feels like it jumps also really bad when taking I corner with a bump feels like its going to spin out underneath me
Old 10-14-2015, 06:20 PM   #7
Like I said its a clone I had a doner wrecked v6 took everything different off of v8 and installed it on this car but like I said it didn't even act right with the v6 in it I had drag radels. On it at that time and I figured it was them but no it still don't it with brand new tires
Old 10-14-2015, 07:42 PM   #8
I would place the car securely on jack stands, with the rear end hanging free, and try to find out where the slop is in the rear suspension. Something must be worn out or broken. Carefully inspect where the control arms connect to the chassis to make sure that the torque box isn't loose.
A panhard bar will help but what you are describing is not normal and should be diagnosed before you start using "bandaids" to try to solve the problem.
Old 10-15-2015, 08:38 AM   #9
smurf stang's Avatar
To be 100% sure put it on a lift to eliminate all doubt.
2016 VW GTI 2.0 Turbo
Old 10-15-2015, 08:53 AM   #10
Strange Mud's Avatar
is this you first solid rear axle car? you will have some movement in the back when you hit bumps.
Old 10-15-2015, 09:06 PM   #11
wbrockstar's Avatar
I would definitely inspect the torque boxes because,if their welds are broken loose,they will definitely make the rear feel loose.I would also check axle shaft movement,side to side.Check the upper & lower control arm mounting brackets,at the axle housing,to make sure the welds aren't broken.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Help Help Help....mustang Princehollie Pre-2005 V6 Mustang 57 03-17-2015 04:58 PM
Help Help Help....1995 mustang 3.8 Princehollie Pre-2005 V6 Mustang 4 07-03-2014 06:42 PM
Baltimore area spark plug insert!! Help Help HELP readytorockyou 1996-2004 Mustang GT 0 04-25-2010 11:37 AM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
Help help help? Seph Mustang Audio & Video 6 02-15-2004 04:35 PM
10:20 AM
