Warning Chime - Mustang Evolution
Old 10-23-2015, 07:07 AM   #1
RoCoBass's Avatar
Region: Iowa
Warning Chime
My warning chime goes off as I open the driver's side door to exit and I don't know what's triggering it. Interior lights/ dome, off. Headlights & Parking lights, off. Key, out of ignition and ignition in the off position. Steering wheel in the locked position. This condition does not drain my battery at all. I'm just puzzled by this.
I can't find my Chilton's so don't have schematics to see what all trigger it.
Have any of you had this situation? Thanks to all that CHIME in
Sent from my XT1526 using Mustang Evolution mobile app
RoCoBass is offline   Reply With Quote
Old 10-23-2015, 08:56 AM   #2
ALMOST STOCK's Avatar
This is from my 89 EVTM
Name:	Ign  And Chime.jpg
Mustang Monthly Jan 2015- Feature
5.0 Mustang & Super Fords July 2005
ALMOST STOCK is offline   Reply With Quote
Old 10-24-2015, 12:27 AM   #3
RoCoBass's Avatar
Region: Iowa
Thanks ALMOST STOCK! After further looking into this situation I found the ignition cylinder is the culprit. It has about 1/8" slop in it. Into/towards the steering column and out/away from it. When I remove the key the from the ignition cylinder, it pulls out away from the column triggering the chime. Push it in 1/8" and it'll turn off. I'll tear into it tomorrow and determine if it's the wire connection or exactly how to fix it. Figured I'd share that info in case anyone gets this problem in their Foxbody.
Old 10-25-2015, 12:47 PM   #4
Jinash's Avatar
Mine does this too! Definitely going to check it out! Thanks for the info
Jinash is offline   Reply With Quote
Door chime issue mrc 1996-2004 Mustang GT 14 04-07-2011 08:45 AM
Door Chime Always Telzinga General Mustang Discussion 6 01-07-2011 10:23 PM
Baton Rouge on Dec 16TH - Kyle, Mike, Others chime in Justin Regional Mustang Discussion 69 11-13-2008 12:02 AM
Door open chime jminnich21 1996-2004 Mustang GT 1 09-27-2008 01:24 PM
kill the warning chime 2006 mustang MARC NUNO Pre-2005 V6 Mustang 14 01-21-2006 08:19 PM
08:16 PM
