3.73 gears - Mustang Evolution
Old 11-04-2015, 10:48 AM   #1
3.73 gears
Hi everyone, I want to buy a different gear for my 94 gt. I have the 8.8 rear end and I would like to get the 3.73 gear, lots on eBay that say it comes out of a explorer with 11x41 tooth count..... Is that good for my car? Is there a tooth count I should look for? Let me know thanks..
pony5.0 is offline   Reply With Quote
Old 11-04-2015, 11:13 AM   #2
Call your parts guy at the dealer, and have him check compatible part numbers. I don't know if anyone here has made the swap your are talking about......I would be surprised if what you describe was able to be swapped.
Old 11-04-2015, 01:40 PM   #3
Don't buy used gears. Spend the little extra for new Ford Racing gears
Sent from my XT1045 using Tapatalk
Old 11-04-2015, 06:30 PM   #4
GT1995's Avatar
Buy a rear end from a 99-04 rear end, it's 1.5 inches wider and comes stock with 3.27 gears... Pretty cheap too, i paid about 400$ for a complete rear end caliper to caliper with 50k miles on it.
This car is a pain in my ***
GT40P Heads, GT40 Intake Manifold, 70mm TB, Cold Air, 24lb injectors, SCT Tuned, need more speeeeed
GT1995 is offline   Reply With Quote
Old 11-07-2015, 02:00 AM   #5
wbrockstar's Avatar
Ford Motorsport gears are the best gears to run,in my opinion. They're also good because backlash usually stays identical to the stock gears,so adjustments normally aren't needed.Its weird for somebody to list a gearset using tooth count instead of just stating the ratio,but a 11/41 is definitely a 3.73 That's just one way of calculating which ratio you have,if the rearend cover tag(which lists ratio)has been removed.You simply divide the ring gear tooth count by the pinion gear tooth count to give you the gear ratio.The link shown below is the junkyard HP thread from the Corral forum.It lists rear ends and gears that are compatible with the Foxbody which came equipped in vehicles other than the Mustang.
http://forums.corral.net/forums/5-0-...r-summary.html
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 11-07-2015, 06:02 AM   #6
Don't buy used gears and then I'd say just get 4.10s. If you are worried about a few hundred RPM on the highway then get a Prius.
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
4:10 gears vs 4:30 gears SwatKatz901 1996-2004 Mustang GT 5 03-24-2012 03:17 PM
3:55 Gears vs 3:73 gears 06Blue 2005-2010 Mustang GT 19 01-04-2012 06:57 PM
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
10:07 AM
