Inner wheel bearing removal - Mustang Evolution
Old 12-09-2015, 12:58 PM   #1
Foxbody91's Avatar
Topic says it all how in the holy h*ll do I get this bearing out of the rotor. I'm doing a 5 lug conversion and i cannot seem to get the bearing out. I do not have a bearing removal kit either so is there a DIY way or is the kit absolutely needed? Click image for larger version
Name:	ImageUploadedByMustang Evolution1449691103.716995.jpg
Foxbody91 is offline   Reply With Quote
Old 12-09-2015, 02:04 PM   #2
BLKBETTY13's Avatar
Flip it on the spindle and ram it home!
BLKBETTY13 is offline   Reply With Quote
Old 12-09-2015, 02:05 PM   #3
BLKBETTY13's Avatar
Shouldn't take much to pop out. If your trying to pry it out that'll never happen. Either pop it out with the spindle or if you have an impact socket with an extension slide thru other side and smack with a hammer.
Old 12-09-2015, 03:05 PM   #4
Shop press. I had a similar situation with a bearing on my wife's CRV and that ****er was not coming out with a slide hammer or anything like that. Shop press had to put a TON of force on it and then CRACK and it pushed out.
Old 12-09-2015, 03:08 PM   #5
BLKBETTY13's Avatar
Question I have is why do you need it out? You don't plan on reusing it do you?
Old 12-09-2015, 05:16 PM   #6
If you remove the grease seal, it should come right out.
Another method is to screw the spindle nut onto the spindle, and then put the rotor onto the spindle, hooking the inner bearing over the nut. Then pull real hard towards you, to knock the bearing (and possibly the seal) out of the rotor, when it hits the spindle nut. Kind of like a slide hammer in reverse.
Old 12-09-2015, 05:18 PM   #7
BLKBETTY13's Avatar
^^^ agree
Old 12-09-2015, 05:24 PM   #8
Foxbody91's Avatar
I use the spindle and nut trick...popped right out and yes I reused it. Something tells me you're gonna tell me that's a no no?
Old 12-09-2015, 05:31 PM   #9
It is not good practice to mix used bearings and races. If the 5 lug rotor has a brand new race, you can probably get away with using your old bearing. Ideally, you should just put a new bearing, race, and grease seal in the 5 lug rotors and then you will be assred that the bearing will seat correctly and there won't be any problems down the road.
Old 12-09-2015, 05:32 PM   #10
^^^ agree
Lol.
I'm not sure why I quoted you...
Old 12-09-2015, 05:34 PM   #11
BLKBETTY13's Avatar
I would've just replaced it all. Your already there. Not very expensive to just get new bearings, seals, and pack em full of grease.
Old 12-09-2015, 05:36 PM   #12
BLKBETTY13's Avatar
Your local Auto Parts store should have it all in stock. Not like you'll have down time waiting on shipping.
Old 12-09-2015, 08:49 PM   #13
Foxbody91's Avatar
Noted. I didn't want to toss a part if it wasn't bad but when y'all put it that way I can't disagree. Preciate the look outs, I might as well replace my used parts since I've got everything taken off
07 rear wheel bearing removal Evilwalker93 2005-2010 V6 Mustang 5 06-21-2015 05:05 AM
Help with pilot bearing removal cstyle408 1996-2004 Mustang GT 5 10-17-2014 11:56 AM
Pinion Bearing or Wheel Bearing? SCCofSV 2005-2010 V6 Mustang 0 09-30-2012 02:43 PM
Inner edge of exhaust ...and all over the back of dailey 2011-2014 Mustang GT 4 03-09-2012 08:38 AM
Inner tie rod ends Justintriner 1996-2004 Mustang GT 2 12-10-2011 01:07 AM
08:55 AM
