upper rebuild 95 cobra 5.0 - Mustang Evolution
Old 12-14-2015, 06:02 PM   #1
my question is this do I use a 6AL. MSD ignition system OR a system with electronic adjustment with this set up.
MSD distributor , f 303 cam, 1.71 rockers, harden steel rods. 255 lph fuel pump, hi flow fuel rail, 41 pound injectors, adjustable fuel rail, Trick Flow Street heat upper and lower intake, Pro charger 6psi.75 millimeter throttle body, 75 millimeter Pro M racing mass air, equal length headers 2.5 inch exhaust with high flow cats and flowmasters.Stock gt40 heads
I think thats it lol
Trace95cobra is offline   Reply With Quote
Old 12-22-2015, 03:33 PM   #2
Your stock ignition system with an aftermarket box to prevent the spark from being blown out is sufficient for your combo. Hopefully the MSD stuff holds up, I 'd recommend Crane if you want any sort of quality or longevity.
Old 12-22-2015, 03:46 PM   #3
Thank you, I'll order a set up tomorrw. I don't want issues.
Old 12-22-2015, 05:02 PM   #4
I had a 95 Cobra making 301/325 with a HCI. I at first had a A9L swap and then went back to the J4J1 when I had it dyno tuned. All I had in the ignition system was a Crane HI-6 and stock everything else. And TBTH for a HCI car you don't even need that.
In hindsight I should have done what you did and just supercharge with a cam swap. Would have been less money and another 125whp.
Just be prepared to shatter 3rd gear in that T5 and potentially have headgasket issues with the OEM TTY bolts.
If you have any other questions shoot, I had my 95 Cobra from 2003 to 2011 and I still wish I had not sold it sometimes.
Old 12-22-2015, 05:10 PM   #5
thank you for the reply. I have a GForce racing transmission pretty sure it will hold up. & I have hardened steel bolts in the heads. thank you again for your reply
Old 12-22-2015, 05:14 PM   #6
Ok if you have the ARP bolts or studs you should be fine.
The GeForce is pretty strong you should be fine. However... just FYI the only real game in town for a rock solid totally bulletproof T5 is Astro. The gearsets are not the same no matter what you get told. Astro is much stronger.
Old 12-22-2015, 05:36 PM   #7
Ok I'll buy one of thoughts as a back up, thanks again.
Old 12-22-2015, 05:41 PM   #8
You're going to buy a $2800 trans as a backup??
I wish I had that kinda money lol.
Old 12-22-2015, 05:47 PM   #9
Yep lol. I'm single so.......
93 Cobra upper intake bolts Chefnick 1979-1995 Mustang GT 8 11-07-2011 08:38 PM
rebuild of a recent rebuild Black99Snake SVT Mustang 12 08-20-2011 05:24 PM
cobra upper intake install vaccum lines problem trickflow211 1979-1995 Mustang GT 3 04-04-2009 08:27 AM
donor rebuild vs current engine rebuild cash05_mustang Pre-2005 V6 Mustang 2 07-01-2006 01:09 PM
98 cobra upper control arms? SpectorV Pre-2005 V6 Mustang 6 08-21-2005 07:46 PM
12:09 PM
