Cross threaded bolts?? - Mustang Evolution
Old 01-09-2016, 04:43 PM   #1
I was installing a new hurst handle kit I bought for my 88 GT, I did everything the instructions said to, and they are stuck in place. I think the bolts may be cross threaded. Both bolts connecting the handle to the shifter won't move. The top bolt just spins and won't move a bit, and the bottom bolt is sort of out. I've tried using brute force and nothing is working. Anyone know anything I could do?
5oh_chris is offline   Reply With Quote
Old 01-26-2016, 08:47 AM   #2
wbrockstar's Avatar
Have you tried sliding a flathead screwdriver or a small crowbar behind the bolt & pry outward on it while you try to back the bolt out with a ratchet & socket or wrench??If it won't fit between the bolt & shifter handle,try to slide the screwdriver between the shifter base & shifter handle then pry outward on it.Is the shifter base & the handle threaded or is only one of them threaded??
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
bolts bolts bolts! bcosta56 1979-1995 Mustang GT 8 10-10-2012 03:08 PM
Stage 8 bolts, but no bracket bolts? CreationNation 1979-1995 Mustang GT 1 04-13-2009 10:00 AM
Why Did the Chicken Cross the Road? 00vertstang The Bar 18 12-01-2004 02:33 PM
True Meaning to Hot Cross Buns!!!! sctalbott The Bar 11 06-10-2004 07:49 AM
The SES light, car must of had a fart cross ways Mustang Val Pre-2005 V6 Mustang 8 01-23-2004 09:22 PM
05:20 PM
