T5 transmission fluid question - Mustang Evolution
Old 01-11-2016, 09:18 AM   #1
Don Tito's Avatar
I have a question about what kind of fluid can I use because I know that Ford recommend automatic transmission fluid but companies like Amsoil recommend 5w30 motor oil.
So what should I use?
Don Tito is offline   Reply With Quote
Old 01-11-2016, 10:50 AM   #2
Don Tito's Avatar
Wish one is the best option for street use?
Old 01-11-2016, 12:46 PM   #3
Every single T5 I ever owned I ran regular Dextron Mercon 3 ATF and they all shifted like butter.
Old 01-11-2016, 06:30 PM   #4
Don Tito's Avatar
And why Amsoil recommend 5w30 motor oil?
Old 01-11-2016, 06:36 PM   #5
I have no clue but that's not right. Please send the link to where it says that as I am real curious.
Old 01-11-2016, 09:11 PM   #6
Don Tito's Avatar
I saw it in a mustang magazine.
Old 01-12-2016, 10:43 AM   #7
Mustang 101, NEVER believe anything you read in the Mustang rags until you triple check it.
Amsoil makes their own ATF/Synchromesh which would work fine but not 5w-30. Sounds like a misprint or an editing problem or the person writing the article was an idiot.
Just hit up your local autozone, get 3 qts of dex/merc 3, drain your trans, put the plug back in, pull the shifter and dump 3 quarts in through the shifter. This would also be a good time to upgrade your shifter if it isn't already and if you do already have an aftermarket shifter, make sure the stops are properly set.
Old 01-12-2016, 05:26 PM   #8
Don Tito's Avatar
Good
Thanks
Old 01-15-2016, 01:04 PM   #9
smurf stang's Avatar
Scotty has you covered. ATF for the win.
2016 VW GTI 2.0 Turbo
Old 02-09-2016, 11:56 AM   #10
Region: Iowa
Mine has a bit of a whine in 3rd gear. I should probably get it changed as a precaution since I don't know when it was, or if it has ever been changed. I just purchased it with 91k on it.
XrayGT is offline   Reply With Quote
Old 02-09-2016, 12:12 PM   #11
TBTH when you buy a used car the FIRST thing you should do when you get it home is all fluids and a full tune up. I would not trust the fluids to be fresh or the plugs/wires to be good on a 91K mile Mustang.
Old 02-09-2016, 02:54 PM   #12
Region: Iowa
I agree. I am busy compiling parts for a full suspension rebuild.
I found some Roush rear shocks but am still looking to find a matching pair for the front since I found out that they discontinued the front struts.
I have Ford Racing C springs, Energy Suspension Master bushing kit and Hotchkiss camber plates so far...
Old 02-10-2016, 06:56 AM   #13
Full suspension on a 04-down car means completely ditching the 4 link suspension setup out back just FYI.
Tune up should still be the first thing. I wouldn't really drive it much till you get that done.
Old 02-10-2016, 07:04 AM   #14
Region: Iowa
Can you give me suggestions about who to look at for the suspension parts you're referring to?
Old 02-10-2016, 08:00 AM   #15
Depends how serious you want to get.
Old 02-10-2016, 08:06 AM   #16
Region: Iowa
It's a weekend toy that may occasionally be autocrossed. I'm not looking to spend a lot of money on something that I'll never be able to recoup my money from.
Old 02-10-2016, 08:13 AM   #17
Then probably just do lower control arms, lower the car and a good wheel/tire setup and that's all. I would not use any CC plates except Max Motorsports or maybe Steeda tho.
If you ever wanted to get serious about handling you need to completely ditch the 4 link setup out back and go to a 3 link, a 5 link or an IRS that has had all the bushings replaced with aftermarket.
Old 02-10-2016, 08:28 AM   #18
Region: Iowa
I have a set of Hotchkiss plates already. They seem pretty stout.
HOW TO: Changing Transmission Fluid on MT82 Manual Transmission Strange Mud 2011-2014 V6 Mustang 16 10-07-2015 10:23 AM
Motorcraft Transmission Fluid or Royal Purple Fluid 2011 Kona Blue General Mustang Discussion 7 10-15-2013 09:38 PM
question about transmission fluid 08gtstang 2005-2010 Mustang GT 3 09-23-2012 08:49 AM
Smell diff fluid or tranny fluid when I get on it? ajpturbo 1996-2004 Mustang GT 0 06-19-2010 09:26 AM
05:50 PM
