Misfire - Mustang Evolution
Old 01-17-2016, 08:06 PM   #1
Misfire
So I just changed the plugs in my 04 and now the check engine light blinks39times, which is misfire I believe and runs like poo. I had to unplug a few things to get to them so should I unplug battery and reset car before going through each one again
angel@ayccy.com is offline   Reply With Quote
Old 01-20-2016, 11:36 PM   #2
Steve96's Avatar
COP issue? Did you replace or rebuild the COPs? Maybe taking them off when doing plugs caused and issue or damaged one?
1996 GT
Old 01-20-2016, 11:54 PM   #3
JOberlander's Avatar
I'd check the wires first. You'd be amazed at how easily they get damaged now compared to the ones we had growing up.
JOberlander is offline   Reply With Quote
Old 01-21-2016, 07:20 PM   #4
Foxbody91's Avatar
Also be sure they are routed correctly. I recently made that mistake and my fox was misfiring horribly.
Foxbody91 is offline   Reply With Quote
Old 01-25-2016, 12:18 PM   #5
Wrong section... Will move later...
Anyway if you did it right a plug change wont throw codes unless something broke.
Did you rebuild the cops?
Did you triple check everything you unhooked or removed is back in place?
Did you check the plug gap before installing?
Did you properly torque the plugs to 12-15ft lbs with anti seize?
Sent from my LG-D801 using Mustang Evolution mobile app
Another misfire 2000MustangGT17 1996-2004 Mustang GT 5 06-24-2009 08:47 AM
#1 misfire 2kslvrgt 1996-2004 Mustang GT 4 02-17-2009 01:26 PM
another misfire! Jeremym831 1996-2004 Mustang GT 4 03-03-2008 10:01 AM
misfire in #1 vramos1 Pre-2005 V6 Mustang 4 09-15-2007 02:24 PM
Engine runs, but hesitate/misfire jaynez31 Pre-2005 V6 Mustang 11 01-17-2006 05:30 PM
12:01 AM
