BBK Ssi - Mustang Evolution
Old 08-07-2008, 11:31 PM   #1
BBK Ssi
Anyone have any experiance with the BBK Ssi Intake system?
snake428CJ is offline   Reply With Quote
Old 08-08-2008, 07:38 AM   #2
Re: BBK Ssi
i have a friend that just installed one, whats your question?
SimplyOrange is offline   Reply With Quote
Old 08-08-2008, 10:07 AM   #3
Re: BBK Ssi
What does he think about it? How much power does it yield as a stand alone upgrade with stock heads and stock cam? Is it worth it?
Old 08-08-2008, 10:18 AM   #4
Re: BBK Ssi
HMMMMM, he loves the intake and i think its a good design, im not sure as a stand alone power improvement as he put it with windsor jr heads and a trickflow stage 2 cam but i think it is a great upgrade, the trickflow intake is also a nice peice. there is also nothing wrong with the edelbrock rpm series intakes either. personally i like the desighn and look of the bbk over the rest though.
Old 08-08-2008, 02:11 PM   #5
Re: BBK Ssi
ok, here is a quick question, Would the AFR 165s with 1.900in Intak valves fit with stock pistons?
Old 08-08-2008, 02:25 PM   #6
Re: BBK Ssi
yes the heads will fit with stock pistons and even with a higher lift cam. As with any head upgrade, Id check the piston to valve clearance just to make sure. Your cam will have an effect on the clearance as well so be careful in choosing it and make sure the cam and heads are a good match.
Benjytps is offline   Reply With Quote
Old 08-08-2008, 11:16 PM   #7
Re: BBK Ssi
Alright thanks, i'll probably call up summit racing tech support for suggestions.
Old 08-09-2008, 10:15 AM   #8
1234's Avatar
Re: BBK Ssi
I wouldnt go with Summit, check out the site sponsors Atomic Performance and American Muscle, they know alot more than Summit would.
Old 08-09-2008, 10:39 AM   #9
bbunt302's Avatar
Re: BBK Ssi
I have a set of AFR 165s with a Comp XE270HR cam and have never had any issues with PV clearance. As said before, you should always check regardless of what you hear from everyone else. Even little things like head gasket thickness can make a huge difference, and every engine is different.
Scary stuff.
Old 08-16-2008, 12:58 PM   #10
silverstangboy's Avatar
Re: BBK Ssi
yup, most people don't realise as well that deck height and how far down the hole you sit is different on every last single rebuild (even piston to piston), not to meantion if the heads have been shaved (even box stock factory, mine yeilded high) is not the same head to head. and Piston to valve clearence is usually played out in thousand's of an inch.
double check, do it, be happy you know your valves will never kiss a piston.
93 mustang notch
~450hp 331 stroker - Sold
BBK problem UTGT 1996-2004 Mustang GT 11 04-04-2014 11:34 PM
BBK Shorties 99-04 V6 blue-saleen Mustang Parts for Sale and Wanted 3 03-22-2011 01:44 PM
BBK shorty help outlawfrog 1996-2004 Mustang GT 23 11-27-2009 08:31 PM
bbk headers dshultz88 Pre-2005 V6 Mustang 5 12-10-2007 11:28 PM
BBK Performance Seph The Bar 4 07-13-2004 06:18 AM
08:13 AM
