Hood won't shut - Mustang Evolution
Old 01-25-2016, 06:04 PM   #1
Foxbody91's Avatar
Hood won't shut
Just happened cannot get my hood to shut and haven't the faintest idea why..is this normal? Btw it's an 88 gt, good is carbon fiber
Foxbody91 is offline   Reply With Quote
Old 01-26-2016, 07:19 AM   #2
wbrockstar's Avatar
Can you get somebody to push & pull on the hood release lever under the dash while you watch the latch mechanism,to see if its going back into the lock position once the lever is released??The latch could be sticking in the release position when you pull the hood release then let go & once you close the hood again,the latch is still remaining stuck in the release position.Try pushing the hood release lever forward then try shutting the hood.If the latch or the cable is sticking,it wont let the release lever snap back into its normal position once you let go of it.The latch bolts can also loosen up,allowing the latch to move so that its hook doesn't catch on the hood.Make sure the hook isn't bent too.If the cable itself is sticking,your better off replacing it rather than trying to lubricate it.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 01-26-2016, 10:09 AM   #3
Foxbody91's Avatar
It looks like the part it locks onto, when I push down on the hood it isn't pushing down on the lock enough to lock, like it's too hard even if I just do it with my hands without pushing down with the hood
Old 02-03-2016, 04:42 AM   #4
Foxbody91's Avatar
Locking mechanism in the front was bent forward I just had to bend back. Sry thought I posted results it was saved in a draft lol
Old 02-08-2016, 06:15 AM   #5
wbrockstar's Avatar
Thanks for updating
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
Old 02-13-2016, 10:22 PM   #6
Glad to hear. Doesn't hurt to spray some lube on it either, had some issues opening my hood when I first got my car back in the summer, sprayed some lube and it was good. You had a little different situation but hey it won't hurt.
Sent from my Nexus 6P using Mustang Evolution mobile app
UltraBlue is offline   Reply With Quote
Dome light won't shut off Mfore33 1996-2004 Mustang GT 4 11-21-2014 05:10 PM
Passenger Airbag Off light won't shut off rotors 2011-2014 V6 Mustang 4 03-28-2013 04:57 AM
Hood won't shut. New latch needed? Bryan02V6 Mustang Paint, Appearance & Detailing 13 09-10-2012 01:18 AM
68 coupe 289 lights come on but won't turn over and headlights won't come on Sixty8 Coupe Classic Mustangs 2 03-07-2009 07:52 PM
Seems someone has "hacked" our server and shut it down.... Brent The Bar 36 04-23-2004 07:17 PM
12:38 PM
