Code 22 BAP Sensor Out of Range - Mustang Evolution
Old 02-13-2016, 11:19 PM   #1
Hey all, first post here. I'm trying to fix code 22 on my 1991 5.0. It has to do with the Barometric Pressure Sensor being out of range. Being that my car is now 25 years old I have a feeling that sensor might have to be replaced. My symptom is a crappy slightly fluctuating idle...very annoying. I will note that I did previously have codes 44 and 94 which I fixed by diagnosing with a smoke test and plugging up some vacuum leaks. But like I said now I have 22. Has anyone ever had this issue and then replaced their BAP (for mass air flow) or MAP (for speed density) and then had the code go away, fixing the idle? Also, I do plan on replacing my O2 sensors soon because I don't know how old they are since I bought the car from the previous owner back in June 2015 and haven't replaced them yet. All advice and help is greatly appreciated. Thanks.
Sent from my Nexus 6P using Mustang Evolution mobile app
UltraBlue is offline   Reply With Quote
Old 02-14-2016, 06:31 PM   #2
wbrockstar's Avatar
This trouble shooting link will help you test the BP sensor & its wiring,but you'll need a multimeter that measures frequency,to test the sensor itself.You can test the BP sensor wiring with a regular multimeter,but you'll need the frequency measuring meter to do the sensor test.
BP/MAP Sensor Code 22 Troubleshooting
To answer your question,yes the BP sensor affects idle,fuel trim & spark advance.
Be sure to check the 10 pin(aka:salt&pepper)connecters
& do the maintenance procedure on them.They can cause idle issues,driveability problems & false trouble codes,if their pinouts are loose or corroded.
Salt & Pepper (10-pin) Connectors Fix[COLOR="Silver"]
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 02-15-2016, 01:54 PM   #3
smurf stang's Avatar
Also before buying new O2 sensors, have you done a full tune up?
I also didn't see any codes for O2 sensors that is why I am asking.
2016 VW GTI 2.0 Turbo
Old 02-15-2016, 02:22 PM   #4
I recently did a pretty good tune up, a couple months ago I got plugs, wires, new distributer cap, and new coil. I'll have to test the BAP Sensor and salt and pepper shakers, I just happen to have one new o2 sensor laying around so that's less money I'd have to spend in case I do replace them.
Old 02-18-2016, 09:28 AM   #5
Replaced BAP sensor and fuel filter as well, she's running great
---------- Post added at 03:28 PM ---------- Previous post was at 03:28 PM ----------
Also cleaned salt and pepper shakers, those are sons of *****es to take off
Old 02-23-2016, 11:05 AM   #6
wbrockstar's Avatar
So the problem must have been caused by a faulty bp sensor.Thanks for updating the thread.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
BAP VS. New fuel pump Usmcdav2011 General Mustang Discussion 2 01-11-2014 11:54 PM
Is a BAP enough? 6SpeedFreak 2011-2014 Mustang GT 3 01-28-2013 09:17 AM
Kenne Bell BAP southernstang00 1996-2004 Mustang GT 14 09-14-2012 10:29 PM
JLT CAI for 03/04 cobra and Kenne Bell BAP slostang Mustang Parts for Sale and Wanted 6 11-04-2008 06:29 PM
KB BAP 40 amp, Lethal wiring upgrade 99MustangGTman Mustang Parts for Sale and Wanted 0 08-24-2008 04:00 PM
07:50 AM
