1995 302 HO swap. - Mustang Evolution
Old 03-01-2016, 02:53 PM   #1
Pirate Bman's Avatar
1995 302 HO swap.
Name:	ImageUploadedByMustang Evolution1456867935.520838.jpg
ID:	197726Click image for larger version
Name:	ImageUploadedByMustang Evolution1456867950.586908.jpg
ID:	197727Click image for larger version
Name:	ImageUploadedByMustang Evolution1456867973.454508.jpg
ID:	197728Click image for larger version
Name:	ImageUploadedByMustang Evolution1456868007.438027.jpg
ID:	197729Click image for larger version
Name:	ImageUploadedByMustang Evolution1456868037.087452.jpg
ID:	197730Click image for larger version
Name:	ImageUploadedByMustang Evolution1456868057.787292.jpg
ID:	197731Click image for larger version
Name:	ImageUploadedByMustang Evolution1456868079.504450.jpg
ID:	197732Click image for larger version
Name:	ImageUploadedByMustang Evolution1456868094.070228.jpg
ID:	197733Click image for larger version
Name:	ImageUploadedByMustang Evolution1456868110.005997.jpg
ID:	197734Click image for larger version
Name:	ImageUploadedByMustang Evolution1456868141.227158.jpg
ID:	197735Click image for larger version
Name:	ImageUploadedByMustang Evolution1456868156.578214.jpg
ID:	197736Click image for larger version
Name:	ImageUploadedByMustang Evolution1456868180.926726.jpg
ID:	197737Click image for larger version
Name:	ImageUploadedByMustang Evolution1456868194.944046.jpg
ID:	197738Click image for larger version
Name:	ImageUploadedByMustang Evolution1456868212.509451.jpg
ID:	197739Click image for larger version
Name:	ImageUploadedByMustang Evolution1456868228.245121.jpg
ID:	197740Click image for larger version
Name:	ImageUploadedByMustang Evolution1456868256.928410.jpg
ID:	197741Click image for larger version
Name:	ImageUploadedByMustang Evolution1456868287.810674.jpg
So here is my project post. I'm making progress starting my 302 swap. The yellow car is the donor car from which I got ; Full motor, exhaust (minus x or h pipe), full suspension, rear end, brake system. From the green car I took the driver seat, pass fender, and strut tower brace. From the third purple car not pictured, I got the black interior panels, dash and carpet. And console. All for $700. Which I felt was a good deal. The problem is I will need to acquire the ECU, wiring harness to my knowledge. I will put the motor on the stand and take a thorough look at the block and internals. I'll be updating as often as I can. For now my initial budget I'm working with will be a solid 3k. Just to get the ball rolling. I will aim for a 300+ HP target. Oh and as I typed I forgot, I Wana aluminum shaft. This is my second project, first in the line of a major job like this. I would like to seek any and all technical advice from the community.
Pirate Bman is offline   Reply With Quote
Old 03-01-2016, 07:11 PM   #2
oxford5pointoh's Avatar
I have a 95 gt wire harness I can sell you.
Old 03-01-2016, 10:48 PM   #3
smurf stang's Avatar
3 donor cars but who is the recipient?
2016 VW GTI 2.0 Turbo
Old 03-02-2016, 03:36 PM   #4
How much do you think?
Old 03-02-2016, 03:38 PM   #5
1995 302 HO swap.
What do you mean?
Sent from my iPhone using
Old 03-02-2016, 03:40 PM   #6
Today's update. Click image for larger version
Name:	ImageUploadedByMustang Evolution1456958391.491339.jpg
ID:	197761 Got the dash out with thanks to Wyatt my friend.
Old 03-02-2016, 03:46 PM   #7
You can PM me an offer. Its in pretty good condition with maybe a few "broken" clips. Nothing that would hurt the way it works. I pieced it together and prob spent 400 on it. They go for 300-400 on eBay when you get it all together generally.
Old 03-02-2016, 07:43 PM   #8
wbrockstar's Avatar
What do you mean?
I believe what he means by recipient is,what year Mustang are you installing the donor cars parts into?? Is it another 94-95 model or a 96-04 model?? I assume its one of the categories listed above,since you're using the fender,dash,carpet,etc and those parts would only work on 94-04 models.If the project car is a 94-95 model,was it already missing the ecu & harness??
I guess were just use to the poster showing pictures of the project car instead of the donor car & that's why smurfstang & myself were curious
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 03-03-2016, 09:21 AM   #9
Tttttrrrrruuuueeeee.......kinda like I wanna know the guy getting the heart transplant rather than seeing the heart first
Old 03-03-2016, 12:14 PM   #10
Jbone007's Avatar
Yes same here lol!
Jbone007 is offline   Reply With Quote
Old 03-03-2016, 11:04 PM   #11
Ah I see my apologies. I had wiped all my photos from my phone in prep to document everything. I am putting all this into my 95. The donor car was also a 95 I believe if not it was a 94. Click image for larger version
Name:	ImageUploadedByMustang Evolution1457071368.207642.jpg
So this is the best photo I still have on hand of the receiving unit. The front clip is damaged and slightly shorter due to a deer encounter, in place of this I will be installing the cobra kit.
Old 03-03-2016, 11:06 PM   #12
Due to the arson which destroyed most of the car. I assumed and found no trace of the wiring or the ECU. Inside. If they did somehow survive I don't feel confident in their functionality from surviving said fire.
Old 03-04-2016, 04:03 PM   #13
wbrockstar's Avatar
So I assume the recipient is a v6 car right or does it just have rims from a 3.8ltr?? Thats the first thing I noticed.If its the 3.8ltr,I can definitely understand why you're swapping a 302 into it.It looks like youve got all the parts needed to do the swap.Youve got alot of work ahead of you,but you seem to have everything covered.Did every bit of the wiring burn behind/under the dash?? I guess it doesn't matter too much,since youve got 3 donor cars to snatch dash wiring from.I wonder if the dash wiring(except for the main ecu harness)is identical or different between the 94-95 3.8 & 5.0??
I feel for ya brother when it comes to working on dash wiring.There's two things I can't stand working on and that's dash wiring & anything related to crawling under the car.Unfortunately those two areas make up a big percentage of the car,so there's no way around that.
Good luck on the project.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
Old 03-06-2016, 08:14 AM   #14
Thanks.
And yea it's my old 3.8 being removed. Don't get me wrong it's been a great motor and I enjoyed it. But it feels like it's getting tired. And well it's time for more power anyways
Old 04-26-2016, 05:49 PM   #15
Update for April 26 Click image for larger version
Name:	ImageUploadedByMustang Evolution1461714569.283329.jpg
I got a harness yesterday and put these in last night. And o really like them now!
Old 04-27-2016, 08:48 PM   #16
Name:	ImageUploadedByMustang Evolution1461811179.228304.jpg
Name:	ImageUploadedByMustang Evolution1461811196.327034.jpg
Name:	ImageUploadedByMustang Evolution1461811218.122329.jpg
Name:	ImageUploadedByMustang Evolution1461811239.457093.jpg
Today's update, brought everything home and payed up. Load up went pretty smoothly. Getting it out of the truck was fun haha, we lowered the motor by crane onto the ground the second or third regroup, bolted up the face plate for the engine stand, got it secure and it now stands freely and safely.
Old 04-27-2016, 08:48 PM   #17
Also we found the H pipe for the exhaust haha
1995 302 Aluminator swap snooking99 1979-1995 Mustang GT 1 10-04-2013 07:24 PM
1995 Mustang Cobra :: 1995 Ford Mustang Cobra jwhayne0001 Member Garages 0 08-20-2011 11:22 PM
1995 Mustang GT :: 1995 Ford Mustang Ripastanky Member Garages 0 06-15-2011 12:01 PM
Hello, ok i have a 1988 302 lincoln mark VII engine that im going to drop in a 1995 v6 mustang? lugaidh General Mustang Discussion 2 03-20-2010 05:52 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
05:42 AM
