Oil leaks 95 gt - Mustang Evolution
Old 03-12-2016, 08:15 AM   #1
Oil leaks 95 gt
Can use some advice on common place for engine oil leaks on my 95 gt.Already replace oil sending unit above filter.Any advice would be helpful.
Thanks,Boys stang;new member
boys stang is offline   Reply With Quote
Old 03-12-2016, 11:14 AM   #2
smurf stang's Avatar
So are you leaking oil......if so where?
Start be degreasing the engine and bay area to see what you are working with.
These older motors can leak due to a clogged PCV valve, valve cover gasket, oil pan, intake manifold gasket, rear main seal......it all depends from where.
2016 VW GTI 2.0 Turbo
Old 03-13-2016, 06:24 AM   #3
95 gt oil leaks
On my second can of gunk.Still searching for leak.Pvc dry,valve covers dry.Thanks for the reply
Old 03-13-2016, 11:40 AM   #4
have you changed your PCV valve AND the screen under it? I have seen the screens blocked solid that they couldn't even be cleaned.
Old 03-14-2016, 03:43 PM   #5
ch0wd0g's Avatar
Check your radiator fluid. If it oily feeling then could be your head gasket.
Are you seeing it on the ground under car?
ch0wd0g is offline   Reply With Quote
Old 03-15-2016, 09:18 AM   #6
PMPerformance's Avatar
check at the bottom of the bellhousing to see if the rear main seal is leaking. Also backs of the valve covers coming down the back of the motor and to the top of the bellhousing.
94 Blown Canary Yellow GT Vert
372WHP/374TQ
PMPerformance is offline   Reply With Quote
Old 03-16-2016, 01:22 PM   #7
Oil likes to travel that is why I said cleaning everything super good will help track down them slimy leaks.
Old 03-17-2016, 09:30 AM   #8
Rear main almost always leaks on these cars unfortunately. Maybe try going to a 5w40 oil?
Sent from my LG-D801 using Mustang Evolution mobile app
Old 04-07-2016, 12:24 PM   #9
Had my power steering return line that was leaking on my 94 GT. Dirty fluid and looked similar to oil.
1994 Mustang GT
Bare Bones Stock
Darin is offline   Reply With Quote
Old 07-03-2016, 07:07 AM   #10
check oil pan gasket.drove myself nuts with oil leak
Oil leaks? Jon3.7 2011-2014 V6 Mustang 18 01-12-2016 09:44 AM
95gt excessive oil leaks, clogged pcv screen. james90LX 1979-1995 Mustang GT 1 11-13-2012 10:01 PM
addressing oil leaks - lower intake r & r Chwriting 1979-1995 Mustang GT 1 03-21-2012 09:18 PM
Diebold Accidentally leaks 2008 election results Brent Pictures and Videos 2 02-25-2008 06:52 PM
2000 Convertible Top Leaks sctalbott Pre-2005 V6 Mustang 2 11-10-2003 08:58 PM
06:35 PM
