Little underwhelmed with recent dyno numbers. Any suggestions? - Mustang Evolution
Old 03-14-2016, 07:32 AM   #1
PMPerformance's Avatar
Hello All,
I recently had my car redynoed with the addition of a Vortech setup and fuel system on my 94GT.
Last year when I had the boltons all put on, I did GT40's and Cobra Intake, Trickflow stage1 cam and a tune and the car was a little underwhelming HP wise. It made 256@301 on a dynojet in the cold weather. I always thought it was the tune, but now on the blower setup with a more known tuners, it made inline with those numbers and again a little underwhelming. This time it made 372@374 on about 10PSI. Weather was probably high 70's this time, so there was likely a bit of heat soak compared to how it was last year this time of year.
I know the heads and intake manifold are holding me back pretty much, but I expected they would atleast break 400 without too much of an issue.
When the cam was installed it was installed straight up dot to dot. The springs I used were Alex Parts springs for the 580 lift cam just in case I went to 1.72 rockers, but Alex stated the seat pressure on these would be ok either way. I ended up going with 1.6 rollers though
So my question is, is there anything relatively easily replaced with little more money in at this point to bump this thing up to over 400whp? I know I can down the pulley a little, but I really expected this to jump more on what it has. Can degreeing the cam at all help? Or just ditch this cam completely?
I know heads and intake will be a huge jump, but I really dont want to rip it all down again right now.
Attached is the dyno sheet and specs on the springs I used for good measure.
Motor and Mods are:
153K mile 302
3Bar GT40's that were refreshed about 1500 miles ago with Alex Parts springs, seals and Scorpion 1.6 rollers and TFS1 cam
FMS shorties, ORH pipe, flowmaster 40's
Anderson Powerpipe with PMAS MH95 on it feeding to a V2SQ. Stock 94-95 Cobra Intake manifold with 70MM throttle body.
Name:	Blower dyno sheet.jpg
ID:	198213   Click image for larger version
PMPerformance is offline   Reply With Quote
Old 03-14-2016, 08:57 AM   #2
smurf stang's Avatar
Did you verify that it was huffing 10 psi? Didn't see it on the graph.
Also the graph looks good but did they play with timing and fuel?
2016 VW GTI 2.0 Turbo
Old 03-14-2016, 09:29 AM   #3
Yea, its a full tune. I trailered it down there because the maf is soo big and the additional bigger fuel stuff I added.
I didnt ask the timing, but he did say it wasnt very conservative. He added a degree in and didnt make much more, and then backed it back out since it didnt liven up much. I want to say maybe 18* of timing, but I cannot be sure on that. Unlike the last tuner, I do trust this one. I didnt bother him much when tuning because I wanted to let him do his thing
I did confirm on the boost gauge, it is seeing about 10psi when I watch it . Not sure if gear loading makes a difference, but I think he said he saw 12 or so PSI at one point. So yea its making boost.
Its the stock 3.3" pulley and has a power pipe and metal pipe for the discharge. I did reuse the upper intake gasket when I had the upper off, but was replaced when I did the heads within the last 1500 miles or so. I guess I can check to see if there is a leak there by chance, but I dont think there is. The car has very good manners other than the lower power. The car did make 116whp and 74ft lbs of tq with the addition of the blower, so I know its doing something.
He did have to tighten the blower belt after the first run, but even with it slipping bad it still made almost 360.
The bottom end seems stout still, but also has 153k miles on it. Compression seemed solid last I checked it. No oil spewing into my oil seperator and I have a check valved breather in the valve cover to avoid too much crank case pressure build up.
To me it seems like more of my "Stock stuff" holding me back, but curious as to if maybe my springs have too much seat pressure or the cam is just wrong for this setup or could use some advance or ****** maybe?
Old 03-16-2016, 11:00 AM   #4
Maybe excessive belt slip still.
Hard to compare dyno numbers as there are so many variables involved.
Sold some GT40's to a guy I know who paired them up with a ported GT40 intake and and all the other stuff. He was huffing approx. 10 pounds and I think he laid down in the same neighborhood. He did have some belt slip as well. I know when he swapped to TFS heads and Holley intake he gained another 70 horses.
Old 03-16-2016, 11:02 AM   #5
He looked like he really tightened the heck out of the belt though. I have the belt off right now because im working on serpentine belt issues right now, but Ill try and tighten it more and see.
Wonder if he just laid timing a little light due to IAT's.
94 Blown Canary Yellow GT Vert
372WHP/374TQ
Old 03-16-2016, 04:32 PM   #6
Adogg's Avatar
What are you using for a fuel system?
Sent from my SAMSUNG-SM-N910A using Mustang Evolution mobile app
Don't hate....... appreciate
Old 03-16-2016, 06:01 PM   #7
Is like to think it's a pretty stout fuel system. I planned for more power so overbuilt.
Walbro gss340 pump, Siemens deka 60's, pmas mh95 slot setup with ba3000 curve, sct chip to take the tune. Otherwise stock lines, stock fpr stock hanger and tank
Fuel deff shouldn't have been the issue
Old 03-16-2016, 06:30 PM   #8
Adogg's Avatar
If there was an issue he should have seen it, depending on what type of tuning he is doing he would be able to see if there is to much or too little. And make sure the maf voltage is correct for that type of fuel. Did you tell your tuner about the low number?
Old 03-16-2016, 06:40 PM   #9
He tuned it, so he is very well aware of the numbers.
Not sure I follow where you are going with this?
So is everyone more willing to point the numbers at the tune and not the hardware used? This guy came extremely reccomended so I lean not to believe soo much the tune.
Plus second tuner on second setup and made less than expected
Old 03-16-2016, 10:53 PM   #10
Adogg's Avatar
Maybe try porting the cobra upper and lower? Maybe that is holding you back
Old 03-17-2016, 05:07 AM   #11
Ill just replace it at that point.
372WHP/374TQ
Old 03-17-2016, 07:25 AM   #12
Adogg's Avatar
That's true if you port the cobra Intake you get to keep a nice look of that cobra Intake and make more power.
Old 03-17-2016, 07:44 AM   #13
True, I kind of like that stockish look, but that the price of having someone like TMOSS port it, Im at a new aftermarket piece that I could actually gain from replacing. I didnt port it before because TMOSS said I wouldnt really gain from it on my NA setup. BUt its upwards of $400 + to get it there, ported and sent back to me.
372WHP/374TQ
Old 03-17-2016, 03:12 PM   #14
Adogg's Avatar
Yea for that price not worth it I use the ford box upper on my turbo set up and like it the no runner look
Old 03-18-2016, 10:46 AM   #15
So no input on the cam or seat pressure of the springs being an issue maybe? I did tighten the belt more yesterday and it was too tight then as you could hear the blower bearings making a different noise. So I loosened it back up
372WHP/374TQ
Old 03-18-2016, 12:59 PM   #16
For that combo your are around the range in hp. Take it to the track and see what she lays down. How does it run?
Remember dyno's are a tuning tool so don't put ttttoooooo much into the numbers even tho people love throwing numbers around.
Old 03-18-2016, 01:08 PM   #17
I mean, it runs like a raped ape. Ill blow off the first few gears by standing on it or rolling burnouts by standing on it. So it goes.
Still gotta get some more seat time and lay into it more on the highway to see how it builds boost in higher gears. I only ever had turbo cars and drove roots style cars and this seems really lazy to build boost in higher gears. Otherwise drives good.
Just got subframe connectors for it and will need some kind of a tire, but I dont expect great times due to traction.
I realize dyno is a tuning tool, but when I got guys telling me Im 50whp short, it concerns me
372WHP/374TQ
Old 03-18-2016, 01:36 PM   #18
Just to make you feel better as I was tuning my car on the street and then on the dyno we kept getting some disparities. Turns out when I dyno'ed on my drag radials I was consistently lower by about 10 hp and this was on a mustang dyno which usually reads lower. I was alittle bummed till we figured it out but I always felt better after I would run a fast car and beat him. They all would come to me and say "Dayum......how much you spraying?". All I would do is pop the hood and say "Good luck finding any lines". I don't think I ever broke into the 400's on the rollers but love the combo as I was never really building a 347 from the beginning as it went from a 302 H/C/I swap to a 347 build. Thing pulls like a diesel all the way to 6,200. Thing makes over 400 lbs of torque from 3200 to almost 5100.
Old 03-18-2016, 01:42 PM   #19
well what makes it worse is these numbers were STD and not SAE and on a Dynojet and not a Mustang dyno. lol. Id be scare to see the actual numbers. lol
Ill see what it does on the track. Feels borderline rediculous on the street though. But its been awhile since I have driven anything semi fast, so Im sure I will get bored with it after a few weeks or drive time. lol
372WHP/374TQ
Old 03-18-2016, 09:32 PM   #20
Could be a number of things if you are losing power somewhere but if it runs real good... dyno numbers are dyno numbers. Get it down the 1/4 for the only number that actually matters. Plenty of ppl nutswing on dyno slips and then get their doors blown off by somone making less power on paper because of overall setup/driver mod/whatever.
And whoever suggested porting the lower... why? GT40s flow 200cfm, so does the stock lower. Porting the intake without the heads does absolutely nothing and porting GT40s is a complete waste of money unless you are DIY and actually good enough to do it properly for the cost of bits and whatever you feel your time is worth.
Could always throw an intercooler on it and pulley it up a little to get 10 psi after the intercooler with a colder air charge.
Old 04-22-2016, 11:00 AM   #21
So I been driving the car around a little more and seeing how hot the IAT's get, I decided to embark on Meth Injection. I have a Devil's own kit coming in next week to play with. Im just gonna try to spray on a small nozzle for cooling and see how it does without the car trying to pull timing with the IAT readings before I get back to the tuner. Not sure I want to lean into the timing much more, but I shall see once I get messing with it.
Also got some NT05's on last weekend and complete world of difference for traction. I see I am not peaking a little more boost than I thought now that I can hook. But dead hook full boost every gear so far, which is a huge improvement over the other tires I had
372WHP/374TQ
new dyno numbers maximus 1996-2004 Mustang GT 3 09-07-2007 03:20 AM
Here's my dyno numbers......... 12second5.0 1979-1995 Mustang GT 19 04-08-2006 10:54 PM
r my numbers a little low greg_g70 1996-2004 Mustang GT 27 07-15-2005 06:22 PM
dyno numbers jedwards242000 Pre-2005 V6 Mustang 7 04-17-2005 03:01 PM
Dyno numbers inside from Amazon Racing.. 03redfire cobra The Bar 19 10-27-2004 05:46 PM
03:04 AM
