1190 5.0 rough start - Mustang Evolution
Old 03-15-2016, 06:53 PM   #1
My 90 5.0 starts perfectly fine when cold but has a rough start issue when the engine is hot the gas needle drops from full to about half a tank but comes back up after a while and white smoke appears right after the start upbut does not show up again after untill its started again i dont see any mixture between the coolant and oil if anyone can help out would br appiciated
5Ohhguy is offline   Reply With Quote
Old 03-18-2016, 12:50 PM   #2
smurf stang's Avatar
Run your codes.
Check your grounds.
What's your fuel pressure?
The white smoke could be a little moisture inside the mufflers. You could also be burning coolant but doubtful if it is only on start up. Check the fluid level to see if it drops.
2016 VW GTI 2.0 Turbo
1190 5.0 rough start 5Ohhguy 1979-1995 Mustang GT 0 03-15-2016 06:52 PM
Rough start 86_turbo_hatch 1979-1995 Mustang GT 2 12-08-2013 07:47 PM
Stalling/rough idle after start up? brianw64 2011-2014 Mustang GT 11 12-18-2012 07:53 PM
Rough Idle/Hard to start when cold CodyNelson 1996-2004 Mustang GT 2 10-03-2012 02:03 AM
Rough Idle and Rough Start Cajun JungleBoy Pre-2005 V6 Mustang 3 04-23-2006 10:33 PM
12:43 AM
