1995 Mustang GT Rough idle and stall - Mustang Evolution
Old 03-15-2016, 08:46 PM   #1
95v686gt's Avatar
Just picked this car up a few weeks ago. It's a 5.0L with a BBK MAF CAI throttle body and off road h pipe. CEL comes on after driving a few minutes. Smog pump has been eliminated unhooked and short belted. From what I researched the distributors are known for going out so that was the first place I started cause I seen really fine black powder in the cap. It has a MSD cap and TFI coil. Also MSD plug wires. After driving about 10 minutes or so sitting at a idle for maybe 3 or 4 minutes the car will start missing give it gas and it will try to Rev but die. Restart and still miss but once rpms past 25k it clears up but acts like it has no power pulling. Ease into it and pulls fine. Open to suggestions. I had the ignition control tested 7 times in a row and it passed. Never even got hot.
Sent from my SAMSUNG-SM-G870A using Tapatalk
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 03-15-2016, 11:43 PM   #2
Check the codes so that you can find out why the CEL is being triggered.
straybullitt is online now   Reply With Quote
Old 03-16-2016, 06:27 AM   #3
95v686gt's Avatar
I have to find that diagram to pull the codes. Funny thing is as long as the car is cold it runs great.
Old 03-16-2016, 10:11 AM   #4
Adogg's Avatar
Msd as of late has been pretty crappy so keep an eye on that and try cleaning the maf and check the tb
Sent from my SAMSUNG-SM-N910A using Mustang Evolution mobile app
Don't hate....... appreciate
Old 03-16-2016, 03:09 PM   #5
95v686gt's Avatar
From the codes I'm getting a TPS ACT ECT and EGR. All the smog piping is eliminated. So I'm leaning towards the TPS being the issue here with the idle and stalling
Old 03-16-2016, 04:04 PM   #6
Adogg's Avatar
That is a good lead, just for my personal experience my car 94 gt was doing the whole no power up top and maf was gross. If you just got the car it would be worth checking just in case.
Old 03-16-2016, 04:05 PM   #7
95v686gt's Avatar
Yeah was going to clean it anyways.
Old 03-16-2016, 10:42 PM   #8
wbrockstar's Avatar
Anytime you get codes for that specific group of sensors,you need to remove the ecm from the kick panel,remove its back cover & look for a burnt signal return trace on the board.All of those sensors share the signal return wire,so test that wire for continuity (ohms)between the signal return terminal at the diagnostic VIP connecter & pinout #46 at the 60 pin connector
(ecm disconnected) You should get 5.0 ohms or less.If not,the wire is open between those two points.
If the wire passes the test,inspect the board.The picture below shows what a burnt SR trace looks like.Check the 3 blue capacitors too for leakage,buldging & broken posts.
The first picture shows the burnt sigrtn line
The second picture shows the burnt line after it has been repaired with a piece of wire
The third picture shows a capacitor & leakage onto its posts.Yours would need to be replaced if it looked like this one.If one of yours is bad,replace all of them while youve got it apart.
Make sure you disconnect the neg battery cable before disconnecting the 60 pin connector from the ecm.
ID:	198329   Click image for larger version
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 03-17-2016, 06:58 AM   #9
95v686gt's Avatar
Well I also discovered my egr is completely gone. The plug was duct taped and stuffed out of sight
Old 03-17-2016, 07:26 AM   #10
Adogg's Avatar
^^ jeez well in that case if I were you I would go over the car with a fine tooth comb and look for things like that.
Old 03-17-2016, 07:30 AM   #11
95v686gt's Avatar
I have been since I seen that. Haven't seen anything else like that. That's the only thing I've seen rigged so far.
Old 03-17-2016, 09:07 AM   #12
95v686gt's Avatar
Built the resistor pack to fool the ecm on the egr. We'll see what happens with it.
Old 03-21-2016, 06:47 PM   #13
Westcoast408's Avatar
Sounds like it could be your distributor
Sent from my SM-G920T using Mustang Evolution mobile app
---------- Post added at 12:47 AM ---------- Previous post was at 12:47 AM ----------
Or egr i was gonna say
99 Mustang GT F.R 3.73s, MGW Short Shifter, BBK Cai, BBK 70mm Throttle Body, Mach 1 Chin Spoiler, SR Lowering Springs, Koni shocks and struts, Mach 1 Grill Delete, Black Billet Fuel Cap, Trick Flow 75mm Plenum, Raxiom Smoked Tail lights, Magnapack Mufflers
Westcoast408 is offline   Reply With Quote
Old 03-21-2016, 07:35 PM   #14
wbrockstar's Avatar
Is this the diagram you're needing to run the koeo & koer test??
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
Old 03-21-2016, 07:37 PM   #15
95v686gt's Avatar
I already did that. Thanks though
Old 03-22-2016, 03:15 PM   #16
smurf stang's Avatar
So what codes did you get?
2016 VW GTI 2.0 Turbo
Old 03-23-2016, 07:23 AM   #17
95v686gt's Avatar
Threw EGR TPS and ACT sensor codes.
1995 mustang
1995 mustang gt rough idle flatstanley1 1979-1995 Mustang GT 4 06-26-2013 03:36 PM
rough idle and stuttering help!! blakesmustang Classic Mustangs 9 06-20-2012 02:55 PM
95 gt rough idle and bucking issue Napoleon 1979-1995 Mustang GT 15 01-16-2012 04:09 PM
My car seems to idle rellay rough, and miss badly johnpittbull 1979-1995 Mustang GT 21 07-04-2006 09:06 AM
Rough Idle and Rough Start Cajun JungleBoy Pre-2005 V6 Mustang 3 04-23-2006 10:33 PM
08:45 PM
