Rubbing issue - Mustang Evolution
Old 03-22-2016, 08:48 AM   #1
mach5894's Avatar
Rubbing issue
I just picked up a 95 mustang and I got some fresh tires on her and over some bumps I hear my passenger rear tire hitting the fender, does anyone happen to know where the bump stops on the mustang go if there is bump stops because I wasn't able to find them
mach5894 is offline   Reply With Quote
Old 03-22-2016, 03:20 PM   #2
smurf stang's Avatar
What size rims?
What size tires?
What springs?
What shocks?
Was the car empty/unloaded?
Are you sure it is hitting the fender and not bottoming out?
2016 VW GTI 2.0 Turbo
Old 03-29-2016, 04:38 PM   #3
wbrockstar's Avatar
Theres a pinion snubber(piece of hard rubber attached to a metal plate)that's attached to the underside of the body that contacts the top of the differential housing to prevent axle hop & excessive upward movement of the axle housing.You can buy an aftermarket snubber that's adjustable which will help reduce movement.The pictures below are a stock snubber & a aftermarket adjustable snubber.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
2004 GT 315 Tire Rubbing Issue TheJigShow 1996-2004 Mustang GT 11 11-13-2011 07:31 AM
Rubbing Scut95 1979-1995 Mustang GT 8 01-19-2006 01:17 AM
Rubbing Alchohol StreetRacer4371 The Bar 7 11-08-2004 12:53 PM
Fixed my "rubbing problem" greenflash00 The Bar 2 02-18-2004 10:51 AM
Getting some rubbing up front...any suggestions? greenflash00 Mustang Wheels & Tires 18 02-08-2004 12:42 PM
07:22 PM
