Resistor check - Mustang Evolution
Old 04-30-2016, 07:25 AM   #1
Don Tito's Avatar
Resistor check
It's anyone know how to perform a test to the resistor that filter the voltage on a 88 5.0 distributor?
Don Tito is offline   Reply With Quote
Old 05-06-2016, 06:10 PM   #2
wbrockstar's Avatar
Just pierce the wire with a needle,on both sides of the resistor,and touch the (+) lead of an ohmmeter to one needle & touch the (-) lead to the other meter.That resistor is rated at 22k(22,000)ohms,so the meter should read somewhere close to that.A resistor is usually good or bad,so it will either measure close to 22k ohms or it will measure OL,which means the resistor is burnt in two.
What kind of issues are you having??
Why are you testing the resistor??
Ive seen code 18 be caused by that resistor being burnt.That resistor is put there to prevent excess voltage (from a spike)from reaching the ecm.The wire,the resistor is spliced into,runs between pin #4 at the tfi module & pin #4 at the ecm harness.Its used for the IDM(ignition diagnostic monitor)
This resistor is used to lower the voltage of the Tach signal being supplied to pin #4 of the ECM.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 05-08-2016, 09:16 AM   #3
Don Tito's Avatar
Thanks for the advice
Airbag resistor kit! McQueen 2011-2014 Mustang GT 26 10-12-2016 11:34 AM
resistor size jdavis96gt Mustang Audio & Video 5 04-28-2012 06:55 AM
Do i need to put resistor if i am going to replace my parking lights to LED? Siendly22 Mustang Audio & Video 11 10-09-2011 09:47 PM
Which Tachometer resistor should I put in? hassin General Mustang Discussion 2 04-04-2010 10:04 AM
IAT Resistor Question Tin Kicker Pre-2005 V6 Mustang 12 01-22-2004 08:38 PM
06:57 AM
