Crankshaft pulley help!!! - Mustang Evolution
Old 04-30-2016, 09:01 AM   #1
Izzy's Avatar
Region: New Mexico
I just got a SVE underdrive pulley kit for a 92 gt from late model, I installed them no problem but when I start it and try and set timing with my light, it only gives me numbers that start at 20 degrees and end at 40 degrees, normally it should say 0-20 degrees, I thought I installed the pulley wrong but there was only one way to Install, my question is did I get the wrong pulley or do I have to adjust the counter weight?? Anything would help cuz I have it timed by ear right now but everyone knows thats not accurate, so anything will help thanks!
Sent from my C811 4G using Mustang Evolution mobile app
Izzy is offline   Reply With Quote
Old 04-30-2016, 01:18 PM   #2
Izzy's Avatar
Region: New Mexico
Correction, harmonic balancer is made by professional products, and thats what I'm reading off of
Old 05-01-2016, 12:25 PM   #3
Izzy's Avatar
Region: New Mexico
Fixed problem, thanks!
Old 05-02-2016, 05:40 AM   #4
smurf stang's Avatar
What was the problem so that others might learn what you did wrong. And congrats on fixing it.
Sent from my SM-G920T using Mustang Evolution mobile app
2016 VW GTI 2.0 Turbo
Old 05-02-2016, 09:38 PM   #5
Izzy's Avatar
Region: New Mexico
Not sure, might have been misunderstanding, when pulley was installed the tech had timed it by ear due not being able to set it at 10degrees base timing, he then set it by "ear" so when I tested that theory, wit my timing light it was at 32degrees Advanced, It was hard to believe due to no back fires occurring, I was then able to drop it down to 10 degrees and now its at 12, we found it run best at twelve with our setup, so,again SORRY about that and just a lesson learned to Verify someone else's work before continuing your diagnosing lol
Old 05-03-2016, 09:20 PM   #6
32 is a hell of a lot.....did you guys disconnect the spout?
Old 05-07-2016, 05:24 AM   #7
wbrockstar's Avatar
I agree,it sounds like the spout plug might have been left in place when he readjusted the distributer. For some reason my mind has gone blank,what would it be sitting at if he leaves it where its sitting right now but pulls the spout to check it??It seems like it would be running with alotof power loss
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Crankshaft Sensor .. Need Help infamous281 1996-2004 Mustang GT 9 08-21-2013 10:59 AM
crankshaft turning socket RepumSN95 1996-2004 Mustang GT 7 03-15-2013 11:56 PM
2013 GT crankshaft Cdgardner1 2011-2014 Mustang GT 9 02-06-2013 10:53 AM
Oil leaking on crankshaft Taxman 1979-1995 Mustang GT 2 04-14-2012 09:40 AM
Crankshaft position sensor? saif02gt 1996-2004 Mustang GT 1 03-31-2011 07:23 AM
» Members Mustangs
Reptar
Adogg
Raven
blancoj17
Add your Mustang
05:05 AM
