Tfi module question - Mustang Evolution
Old 05-01-2016, 04:46 PM   #1
Don Tito's Avatar
Tfi module question
I have an a '88 5.0 and my question is
It is possible that if the tfi module have something wrong can the pcm go to base engine timing?
Don Tito is offline   Reply With Quote
Old 05-02-2016, 08:00 AM   #2
95v686gt's Avatar
No.
95 GT BBK CAI TB MSD 6AL O/R H SLP LM1
Coming soon GT40 Heads Intake and e303 cam with Long tubes
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 05-06-2016, 08:31 PM   #3
wbrockstar's Avatar
So the timing wont advance??Is that the only issue??
Is the spout plug in place??Make sure its not loose.Make sure the wires have continuity,that lead to the spout connecter.An open in one of its wires could cause no timing advance too.You can also remove the spout plug & install a jumper wire in its place,to see if that allows timing to advance.The spout plug can develop an open inside it,just like a fuse blowing,and that will prevent the ecm from advancing timing.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 05-08-2016, 10:19 AM   #4
Don Tito's Avatar
But if is a short in the spout plug it will set a fault code?
Old 05-10-2016, 08:35 AM   #5
smurf stang's Avatar
So Don just explain what you are trying to do and what is happening?
2016 VW GTI 2.0 Turbo
Old 05-10-2016, 08:36 AM   #6
95v686gt's Avatar
+1
Sent from my LGMS330 using Tapatalk
Old 05-11-2016, 06:41 AM   #7
Don Tito's Avatar
I find the problem, it was the pickup coil in the distributor. I replaced for a complete new unit from AutoZone and that solve the problem.
Thank you guys.
Tfi module 4eyesvt 1979-1995 Mustang GT 2 05-17-2013 02:58 PM
Need Help with TFI Neville J Pre-2005 V6 Mustang 4 05-05-2013 10:16 AM
TFI 94GT302 1979-1995 Mustang GT 1 10-24-2012 11:35 PM
Venom 400 Control Module greenpony02 Pre-2005 V6 Mustang 1 03-15-2004 04:24 PM
VENON400 Performance Module..How much HP/Torque gain REALLY? yellowgt6 Pre-2005 V6 Mustang 8 10-08-2003 11:29 PM
02:11 AM
