Vacuum system - Mustang Evolution
Old 05-04-2016, 08:16 PM   #1
Tlong93's Avatar
Vacuum system
Should the vacuum hose from the intake to the charcoal canister be hard or soft the line that goes under the intake is hard then splits into a line that's very soft I've been having issues out of this car and trying to weed out possible problems. 88 fox with the 5.0
Tlong93 is offline   Reply With Quote
Old 05-06-2016, 04:33 PM   #2
wbrockstar's Avatar
The one that came stock on mine is just like you explained,but you can replace it with a regular piece of vacuum,fuel or coolant hose thats one solid piece of hose,instead of splicing different type/lengths of hose together.Ive got one piece of hose that reaches from the purge valve to the intake then another hose from the purge valve to the canister.I believe they used that hose setup,with the plastic splice,so you can disconnect the hose at the distributer but still leave a short piece attached to the intake(which is damn near impossible to reach without removing the upper intake or working with some long *** needlenose pliers in a confined area)That soft hose likes to dryrot too,especially at the canister end.If you wanna keep it so you can disconnect it at the distributer,just use a plastic splice at that spot,then you can put a hose clamp on it at the intake port so it will never come loose.If youre not gonna use a splice,so it can be disconnected,dont put a hose clamp on it because it'l be a pain to get off.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 05-10-2016, 07:58 AM   #3
smurf stang's Avatar
Man and I thought we were gonna talk about my new Dyson.
2016 VW GTI 2.0 Turbo
stock sound system vs. shaker audio system (2014 Mustang) Charlesph55 Mustang Audio & Video 6 02-15-2017 07:11 AM
Eibach Pro-System-Plus vs. Eibach Sport-System-Plus MustangGT02 1996-2004 Mustang GT 15 01-12-2013 03:45 PM
need opinions on new sound system for 98 cobra with Mach system tennisfreak802 Mustang Audio & Video 7 04-28-2010 02:29 PM
Name that vacuum hose... A5295 1979-1995 Mustang GT 3 11-27-2007 07:17 PM
Vacuum booster Black Panther Pre-2005 V6 Mustang 2 02-12-2007 10:45 PM
03:12 AM
