1994 Mustang GT Idle Issues - Mustang Evolution
Old 05-07-2016, 02:25 PM   #1
Region: Nevada
Hello all,
I am experiencing some idle issues, where at initial start, the car idles fine, but about after a min or two...the idle surges, repeatedly, as if I am stepping on the gas and then returns to normal. My car was idling perfect, until I replaced the power steering pump. While replacing the pump, the battery cable made contact with the terminal while the key was turned to the "on" position. My concern is that the power bump may have thrown something off. I have checked the MAF sensor, TPS and they both seem to be working fine. I did recently change the o2 sensors as well, but this was after I was having the idle issues. Any help or suggestions would be appreciated. Thanks.
Shelton is offline   Reply With Quote
Old 05-10-2016, 07:02 AM   #2
smurf stang's Avatar
I would start and always start with a running of your codes....fast, free and informative.
http://sbftech.com/index.php/topic,2471.0.html
http://sbftech.com/index.php?PHPSESSID=7261a4935687afe79b81c982b1b049ec&/topic,849.0.html
Also good to do a base idle reset http://sbftech.com/index.php/topic,1031
2016 VW GTI 2.0 Turbo
Old 05-10-2016, 03:46 PM   #3
Region: Nevada
Thanks for the response. I ran the codes... and if I read them correctly. Below is what I came up with:
542 - Fuel Pump Circuit Failure
122 - TPS Below min .6 Volts
123 - TP Circuit Above Max 4.5 Volts
177 - O2 Sensor Circuit indicates system rich (Left Side)
327 - DPFE or EVP circuit below min voltage of .2 volts
Old 05-12-2016, 07:37 AM   #4
95v686gt's Avatar
Did you run KOEO then the KOER? Might pull the ECM and look for a burnt spot on the board. Could have surged it. But clear the codes and do the idle reset like was said above before suspecting the ECM.
Sent from my LGMS330 using Tapatalk
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
1994 mustang
Set Idle Screw / Idle problem v8pony 1996-2004 Mustang GT 8 05-15-2015 10:07 PM
2010 GT - issues, issues, issues. Anyone experience this? Binks 2005-2010 Mustang GT 2 05-09-2015 10:22 AM
1994 Mustang GT :: 1994 Ford GT Anton94GT Member Garages 1 02-27-2015 06:55 PM
1994 Mustang GT :: 1994 Ford GT Anton94GT Member Garages 0 01-03-2015 08:27 PM
Help! Vacuum issues 1994 GT. sam13708 1979-1995 Mustang GT 3 08-29-2012 07:09 PM
07:48 AM
