Leaks - Mustang Evolution
Old 05-14-2016, 03:01 PM   #1
Tlong93's Avatar
Leaks
Would it be the lower intake gasket if there's a lot of oil on the upper back side of the motor and on top of the transmission. I put my hand back there and can feel the gasket sticking out pretty far didn't seem normal possibly the cause of my vacuum leak
Tlong93 is offline   Reply With Quote
Old 05-14-2016, 06:57 PM   #2
jhall27's Avatar
Spray some Carb cleaner in that area and see if the idle changes or starts missing, if so you have a leak there.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
jhall27 is offline   Reply With Quote
Old 05-18-2016, 09:15 AM   #3
smurf stang's Avatar
It could even be the pcv valve or the screen under it all clogged up. Best bet is to clean up the area really well and see where it starts.
Sent from my SM-G920T using Mustang Evolution mobile app
2016 VW GTI 2.0 Turbo
Old 05-24-2016, 08:34 PM   #4
wbrockstar's Avatar
+1 ^^^
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 05-24-2016, 08:37 PM   #5
wbrockstar's Avatar
This is a well known leak area for the Foxbodys.The rear main seal is another leak prone area.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
Old 05-25-2016, 09:44 PM   #6
Ssssooooooo....
addressing oil leaks - lower intake r & r Chwriting 1979-1995 Mustang GT 1 03-21-2012 10:18 PM
Leaks Snapple750 1996-2004 Mustang GT 2 08-13-2011 11:59 AM
1971 rear window leaks. HELP! Snowmoose14 Classic Mustangs 8 04-17-2011 06:17 PM
Diebold Accidentally leaks 2008 election results Brent Pictures and Videos 2 02-25-2008 07:52 PM
2000 Convertible Top Leaks sctalbott Pre-2005 V6 Mustang 2 11-10-2003 09:58 PM
03:47 PM
