Foxbody won't start please help - Mustang Evolution
Old 05-28-2016, 03:06 AM   #1
I have a 88 gt. I pulled engine and Trans to do my build put it back in. I did a mass air conversion with a A9L computer. Everything is hooked up but it will not start. I can turn key to on position fuel pump turns on. When I go to turn it over it does nothing not a sound at all. If I leave key on and jump the silonide it fires right up and runs. Can anyone help me with this.
88stanggt is offline   Reply With Quote
Old 05-28-2016, 03:56 AM   #2
Did you use a donor car for the mass air conversion or aftermarket kit?
Bigshow14 is offline   Reply With Quote
Old 05-28-2016, 04:25 AM   #3
Was a pro m harness from lmr
Old 05-28-2016, 08:15 PM   #4
wbrockstar's Avatar
Are you sure you plugged all of the wiring harnesses in,on the transmission?? If the starter will turn over by jumping the solenoid posts,the issue is usually a bad ignition switch or clutch safety(manual)neutral sense(auto) switch.The clutch safety switch is at the clutch pedal & the neutral sense switch is at the transmission.
If youve got a 5 speed,disconnect the harness from the clutch safety switch & insert a 5 amp fuse into the harness terminals.Attempt a startup.If it starts,the clutch safety switch is bad.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 05-29-2016, 07:12 PM   #5
It is getting no power to the small wire at top of solenoid and I will try that
Old 05-30-2016, 08:21 PM   #6
I put the 5 amp fuse in today n it fires right up thanks wbrockstar. I'll get a new one ordered n let ya know how it goes.
Old 06-02-2016, 05:38 AM   #7
wbrockstar's Avatar
Glad you got it running again
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
Old 06-30-2016, 09:10 AM   #8
I changed out the neutral clutch safety switch and it still does nothing. If I put a 5 amp fuse in the black connector it will start. I've check all wires on transmission everything is hooked up tight. I'm lost don't know what to try next.
foxbody
My 92 mustang died please help please wont start HybridTruth93 1979-1995 Mustang GT 2 05-04-2014 03:07 PM
put Cai on,now car won't start HELP please. 01mustang_gtfun 1996-2004 Mustang GT 19 03-07-2013 10:37 PM
99 v6 Won't Start PLease HELP brie2888 Pre-2005 V6 Mustang 13 01-15-2011 10:03 AM
Mustang Won't Start Please Help brad12 1979-1995 Mustang GT 7 04-15-2010 08:35 AM
10:33 PM
