H/C/I questions - Mustang Evolution
Old 06-09-2016, 12:37 PM   #1
93fox's Avatar
H/C/I questions
Hello everyone!
Last year I started the process of an h/c/i swap and a few other minor modifications. During the process funds got tight so I had to put it on the back burner. I'm not ready to break back into the project and have a few questions. So far I have gt40p heads that I just got back from the machine shop to have them tanked, looked over very well and had new springs, retainers, etc.. installed. I also have an e303 cam, 1.6 TF RR, Holley systemax 2 intake, and a few other supporting mods. As i'm in the process of cleaning and re-assembly, I have a few questions. WIll I be able to use my stock length pushrods with that setup? I know the TF spring kit installed is capable of handling more lift than the ecam provides, but I wasnt sure if I would have any problem with piston clearance with the new heads? Any and all input is valued. Thanks!!
93fox is offline   Reply With Quote
Old 06-10-2016, 11:31 PM   #2
93slowstang's Avatar
Originally Posted by 93fox View Post
Hello everyone!
No your stock pushrods will likely not work with that setup. You will need the tool to measure your needed length and order accordingly. You should have no problems at all with ptv clearance since you're using 1.6 rockers.
Old 06-12-2016, 06:00 PM   #3
You always have to measure for pushrod length. Always.
Sent from my LG-D801 using Mustang Evolution mobile app
2000 Mustang GT Steeda #0048
Old 06-19-2016, 07:09 PM   #4
93fox's Avatar
Awesome, got it figured out. Thanks!!
Old 06-20-2016, 04:35 PM   #5
smurf stang's Avatar
Did you measure them?
2016 VW GTI 2.0 Turbo
Old 06-22-2016, 12:20 AM   #6
93fox's Avatar
Yes, was able to use stock length.
Old 06-22-2016, 12:42 AM   #7
Did you measure with a solid checking lifter and get the witness marks dead center on the valvestem too?
Old 06-23-2016, 11:06 PM   #8
93fox's Avatar
Yep, was running into trouble because I wasn't torquing the pedestal mount rockers so it was throwing off my measurements. But after i figured that out everything went smoothly.
V6 into a non-V6 car.. plus other questions.. phlegm The Bar 3 09-20-2003 07:08 PM
just a few final questions before the new gears go in... chris92084 Pre-2005 V6 Mustang 4 08-10-2003 11:11 AM
Few quick questions about paint jobs DropTop_Stang Mustang Audio & Video 4 08-07-2003 05:16 PM
***Read Before Posting Questions About Exhaust*** stangin99 Pre-2005 V6 Mustang 1 08-06-2003 10:33 PM
several Questions all good stuff tire Pre-2005 V6 Mustang 19 07-20-2003 11:36 AM
08:46 AM
