Low fluid monitor module - Mustang Evolution
Old 07-08-2016, 06:09 PM   #1
Don Tito's Avatar
Anyone know where is the location and how looks the low fluid monitor module on an '88 Stang?
Don Tito is offline   Reply With Quote
Old 08-05-2016, 07:58 AM   #2
ALMOST STOCK's Avatar
On an 89 it would be here.
Name:	Low Fluid Indicator.jpg
Mustang Monthly Jan 2015- Feature
5.0 Mustang & Super Fords July 2005
ALMOST STOCK is offline   Reply With Quote
Old 08-05-2016, 12:12 PM   #3
smurf stang's Avatar
Mister Diagram/Picture is back
2016 VW GTI 2.0 Turbo
Old 08-05-2016, 12:18 PM   #4
Old 08-06-2016, 06:06 AM   #5
Don Tito's Avatar
Thanks
Old 08-06-2016, 06:07 AM   #6
Don Tito's Avatar
One more question
Did you know how to troubleshoot the antislush module?
Old 08-06-2016, 09:07 AM   #7
You'll need to remove the Anti Slosh Module from behind the back of the dash and check the capacitors.
You could also try this;
Remove the “anti slosh module” located on the back of the instrument cluster. There was a single Torx screw holding mine to the cluster.
Find the electrolytic capacitor. It will be the largest, 2 wire component on the board. The capacitor may have a red or blue plastic wrapper on it.
The wrapper should have printing on it. Look for printing that looks something like this:
100uF+25V
The “100uF” tells you this is a 100 micro Farad capacitor. The “+25V” tells you the capacitor is rated for 25 Volts. Yours may be different. You may use a higher voltage part but don't use a lower rated voltage part. If you use a lower voltage part the capacitor might open later on down the road or it could be as bad as catching fire.
If you can’t find the printing you’ll need to remove the part. You have to anyway so nothing wasted. However pay close attention to the way the capacitor is oriented on the board.
One end of the capacitor will be bare metal with a wire sticking out. The other end should have some sort of insulation over it with a wire sticking out. The bare metal end is the negative end while the insulated end is the positive end. Pay attention to which end is connected to which hole on the board.
Get a replacement part. I got mine at Radio Shack, $1.39. Here’s the info:
100µF 35V 20% Axial-Lead Electrolytic Capacitor
Model: 272-1016 | Catalog #: 272-1016
Replace the part and put everything back together.
ID:	204003   Click image for larger version
Name:	Anti Sloch Front and Rear.jpg
Old 08-24-2016, 11:07 AM   #8
Don Tito's Avatar
I hear that it can be jump. But how can I do that?
Motorcraft Transmission Fluid or Royal Purple Fluid 2011 Kona Blue General Mustang Discussion 7 10-15-2013 09:38 PM
Secondary Air Injection System Monitor Circuit Low Voltage BruThru2002 Pre-2005 V6 Mustang 6 03-23-2011 04:02 PM
2011 Mustang "Low Windshield Wiper Fluid" Preston 2011-2014 Mustang GT 19 03-02-2011 06:50 PM
Smell diff fluid or tranny fluid when I get on it? ajpturbo 1996-2004 Mustang GT 0 06-19-2010 09:26 AM
Anyone low on blinker fluid? Smokedawg The Bar 7 02-21-2004 01:07 PM
05:04 PM
