a/c not blowing cold 95 mustang gt - Mustang Evolution
Old 07-18-2016, 09:49 PM   #1
got a 95 mustang gt 5.0 thats not blowing cold air. freon is where it needs to be, a/c clutch is kicking on an off like its suppose to. only thing i dont understand is the fan will not turn on when i turn the a/c on. if im not mistaken its suppose to. itll turn on when the temp gets up id say when it hits the A in normal. i checked the wires at the fan an i only have a ground wire comin to the fan. no hot wire. thanks
dairey88 is offline   Reply With Quote
Old 07-23-2016, 11:07 AM   #2
Haav2's Avatar
Check the valve that goes screwed onto the top of your accumulator thats what send the signal for your compressor to turn on. you can test if it works by removing the valve and running a jumper wire from both leads to kick your compressor on and might have something to do with turning the fan on/off.
you can try wiring that fan direct to ignition switch for now to see if that helps with the fan situation.
Haav2 is offline   Reply With Quote
A/C stopped blowing cold air MedicDave 2005-2010 Mustang GT 2 08-30-2015 03:38 PM
Mustang a/c just quit blowing cold air paulflor98 2011-2014 Mustang GT 30 08-14-2014 05:45 PM
Right side not blowing cold air Drakma675 2005-2010 V6 Mustang 5 10-14-2013 04:10 AM
Cold snowing wind blowing whats it like near you Mlarv5 The Bar 6 01-31-2013 07:29 PM
A/C not blowing cold USMCSS 1996-2004 Mustang GT 4 05-30-2007 03:09 AM
06:06 PM
