Coolant reservoir needs to be relocated - Mustang Evolution
Old 08-19-2016, 10:05 AM   #1
Shadow91's Avatar
Hey guys, I just put a new radiator in with twin fans, and there is no place now to mount the reservoir. Anyone else have this issue, but came up with a idea as where to move it?
Sent from my SM-G928V using Mustang Evolution mobile app
Shadow91 is offline   Reply With Quote
Old 08-19-2016, 01:18 PM   #2
smurf stang's Avatar
Can you make a little bracket out of some steel and just move it further out or away from the fans?
2016 VW GTI 2.0 Turbo
Old 08-19-2016, 01:27 PM   #3
Shadow91's Avatar
I'm thinking I may have to relocate the battery to the trunk and mount the tank in its place. There is literally no room
Sent from my SM-G928V using Tapatalk
Old 08-19-2016, 01:28 PM   #4
Shadow91's Avatar
The fans sit flush but take the length of the radiator.
Old 08-20-2016, 03:14 PM   #5
wbrockstar's Avatar
Im not sure if the overflow reservoir has to be mounted within close proximity to the radiator or if it can be mounted anywhere?? If it can be located elsewhere, without negative issues,I would go to the pull-a-part or buy aftermarket and get a bottle that'll fit in front of your cai tube,on the passenger side of the radiator.I believe you can buy a round canister shaped bottle that might fit nicely.Another location would be inside the driver fenderwell,if you were willing to do away with the windshield washer reservoir, that currently resides at this location. You would have to access the reservoir(for fillup)from the existing hole in the fenderwell or buy a squared off reservoir with a filler neck that will protrude slightly through the existing hole.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 08-20-2016, 03:53 PM   #6
Shadow91's Avatar
That's a great idea actually, thanks for the idea!
Old 08-22-2016, 02:52 PM   #7
wbrockstar's Avatar
I see that youre located in Smyrna,Tn.If you need somewhere to buy take-off or aftermarket parts,and youre not already aware of their existence, Delk Performance is located in Lebanon,Tn.Its a good place to get performance parts,especially if you need it in a hurry.Theyre located on Fall Creek Rd,directly across from the Super Speedway off of 840.
I dont know if there are any junkyards near you or not,but Pull-A-Part is right off of Centennial Blvd,in West Nashville,and theyve got a ton of cars you can search through,if youre trying to stay with that oem plastic look.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
Checking coolant reservoir kclight01 2005-2010 V6 Mustang 4 01-02-2016 07:36 PM
Why is my coolant reservoir getting empty phantom_5_liter 2011-2014 Mustang GT 8 12-09-2015 02:20 PM
99 mustang gt 4.6 coolant reservoir smells like fuel=/ diego23 1996-2004 Mustang GT 0 08-07-2014 03:55 PM
Coolant reservoir/tank swap BlueMonster Pre-2005 V6 Mustang 2 03-07-2013 09:46 AM
battery relocated whipster24 Pictures and Videos 21 12-28-2004 06:10 PM
10:11 AM
