Oil Pump Replacement - Mustang Evolution
Old 09-28-2016, 01:39 PM   #1
Just looking at a car that the current owner believes it might need an oil pump. If this is the case I have found the oil pumps are under $50 generally, but what would be the time on replacing this part in the car? It is a 1994 with over 100k. I am pretty interested in the car but if this is going to be a $500 plus repair I might have to pass on it.
What do you guys think?
jared6180 is offline   Reply With Quote
Old 09-28-2016, 01:56 PM   #2
jkeaton's Avatar
I'm pretty sure you have to lift the engine or drop the k member to get the oil pan off. Not a cheap repair.
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is online now   Reply With Quote
Old 09-28-2016, 02:41 PM   #3
Junior Member
86mustanglx's Avatar
Region: Alaska
Jkeaton is correct I believe. Because the oil pan is dual sump, the engine either has to be raised very high, or the K member must be dropped to remove it and access the oil pump. I would be wary anyway. How does the current owner know it needs an oil pump? Maybe it just needs a pressure sender...
86mustanglx is offline   Reply With Quote
Old 09-28-2016, 02:47 PM   #4
The current owner says he is not 100% sure, but it is what he thinks it is. Neither of us are mechanics. What would a pressure sender cost to replace?
Old 09-28-2016, 02:51 PM   #5
Junior Member
Region: Alaska
The pressure sender would be short money to replace as if I recall correctly, its just a switch. What should really be done, is a mechanical oil pressure gauge should be used to check the oil pressure which will tell you whether it is a sender / cluster issue, or a mechanical issue. Have you heard the car run? Does it sound normal? Even an oil pump is not too bad a job if the car can be had for real cheap. The issue is the problems you get from oil starvation if the engine was run excessively with low or no oil pressure.
Old 09-28-2016, 03:01 PM   #6
I am planning to visit with the guy and see the car this weekend. His statement about how it runs was that it starts fine, "but she will start ticking after a couple miles because the pump gets weird...the car doesn't leak or burn oil."
He also stated a compression test was done and all cylinders fire good and even.
Old 09-28-2016, 03:20 PM   #7
parkerbickel's Avatar
Most shops charge a bay fee usually around $100 to inspect a car. I would see if you could come to an agreement to split the cost 50-50. That way if it's a easy fix you know for sure, and if not you're only out about $50 and not the entire cost of the car.
2011 V6 Race Red - Roush Axle Back Exhaust, GT500 Steering Wheel, GROM Audio Bluetooth Module, Raxiom Aero Smoked Tail lights, Raxiom GPS
parkerbickel is offline   Reply With Quote
Old 09-28-2016, 03:30 PM   #8
The car is worth what he is asking even if it is a $500 or more repair. Either way I would pay it, but if it is an inexpensive fix I could get it done much quicker. Plus my mechanic is a friend and Mustang enthusiast. I just like having a clue about what is happening and heck, maybe even fix it myself! If it is the oil pump, its going to the mechanic for sure!
Old 09-28-2016, 04:55 PM   #9
Junior Member
Region: Alaska
If the car is worth it either way, just go for it man!
Old 09-28-2016, 11:43 PM   #10
That's what I am thinking about doing. I am going to see the car this weekend. If the pics are any indication, I will be buying it.
I did find out the Oil Pump and install is a 2 day job at the shop I use. $1,000.
Old 09-29-2016, 04:24 AM   #11
Junior Member
Region: Alaska
That's no so bad, I would heed the advice mentioned above and ask the shop to actually diagnose the issue so you know what you are dealing with for sure. I've had many customers who decide to wave diagnosis and just have me install a part, and a lot of the time, it does not end up fixing the issue.
Old 09-29-2016, 06:59 AM   #12
I would try to get the diagnoses before buying and let him think it's a requirement for the purchase. It would only cost you about $50 more and you would actually know what it is. Worst case is he doesn't agree to those terms and you could just say never mind I'll buy it without it.
Sent from my SM-G935V using Mustang Evolution mobile app
Old 09-29-2016, 11:49 AM   #13
Spoke to my mechanic again and he said he was under the impression this was a 2011+ 5.0. I told him it was a 1994. It will be much less expensive on a 94!
Old 09-29-2016, 12:13 PM   #14
jkeaton's Avatar
Still have to drop k member or lift the engine though.
07 V6 Coupe
Old 09-29-2016, 12:46 PM   #15
Yes, but I won't do it until I have some other performance parts ready to be put on at the same time.
Old 09-29-2016, 01:36 PM   #16
jkeaton's Avatar
So your going to drive it with a possible bad oil pump until you can buy some more parts? Or just buy it and park it?
07 V6 Coupe
Old 09-29-2016, 01:41 PM   #17
Buy and park. Why would I risk further harming the car. I'm even having AAA tow it home. No reason to put the entire motor at risk.
Old 09-29-2016, 03:44 PM   #18
jkeaton's Avatar
Sorry. You did not specify your intentions.
07 V6 Coupe
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 11:37 AM
1994 Mustang GT Water Pump Replacement Help? BrKu789 1979-1995 Mustang GT 6 12-27-2010 08:13 AM
power steering pump replacement 04TRV6 Pre-2005 V6 Mustang 1 03-05-2010 06:18 PM
WTB: Electric Air Pump (smog pump) MagnuM Mustang Parts for Sale and Wanted 0 05-16-2007 10:10 AM
water pump replacement Ponycarman Pre-2005 V6 Mustang 3 01-16-2004 10:26 PM
01:33 PM
