Sticky gas pedal - Mustang Evolution
Old 10-02-2016, 05:33 PM   #1
Sticky gas pedal
The gas pedal on my foxbody feels kind of sticky. When startng from a stop i cant ease into it you have to be very easy or press it down a little harder than it should be. Does anyone know what this could be?
Murdered5.0 is offline   Reply With Quote
Old 10-02-2016, 06:22 PM   #2
Haav2's Avatar
i might have to do with your throttle body and throttle cable. last weekend i took off my throttle body to clean it up. installed new gasket, after i put it back in i noticed i had the same problem. moving from a stop feels like an on/off switch and i can't ease into the throttle like i was able to before i took it off. i will try to fix mines tomorrow and will let you how it went.
Haav2 is offline   Reply With Quote
Old 10-02-2016, 06:28 PM   #3
That would be great
Old 10-02-2016, 09:02 PM   #4
Could it possibly be the set screw thing on the throttle body?
Old 10-02-2016, 11:17 PM   #5
If someone mistakenly tried to adjust the idle by turning the set screw, it is possible that could be the cause of the "sticky" feeling.
Also, the bushings on the throttle shaft can become worn over time, and the shaft will not move freely.
I had to replace the throttle body on my 91 F250 a couple of years ago. It became sticky after being cleaned. I believe that the bushings are coated with Teflon. When I cleaned it the last time, I probably cleaned out the remaining 20+ year old Teflon.
Old 10-02-2016, 11:22 PM   #6
Should i clean my throttle body than? A couple of my buddies have said wd40 on the gas pedal might help
Old 10-02-2016, 11:52 PM   #7
You should try to diagnose whether the problem is with the cable/pedal assembly, or if it is the throttle body. Disconnect the throttle cable from the throttle body, and with the engine running, manually operate the throttle. See if you can feel any binding, or stickiness, in the throttle shaft. It should move smoothly from idle, with a small amount of resistance from the return spring.
And yes, clean the throttle body if it is dirty. As I said, you run the risk of "cleaning" the lubricating material off of the bushings, but it is one of those "damned if you do, damned if you don't" scenarios.
Old 10-02-2016, 11:55 PM   #8
Is there any certain cleaner i should get?
Old 10-03-2016, 12:00 AM   #9
There is a cleaner specifically for cleaning throttle bodies, that is available at the auto parts stores.
Old 10-03-2016, 12:06 AM   #10
I have read that it sais not to use cleaner because it will take off the rust protective coating
Old 10-03-2016, 12:23 AM   #11
I've heard the same thing over the years. And it is the cleaner that caused my throttle body to fail.
By all means, if you can get the throttle body clean by mechanical means (no chemical cleaner) do so!
But don't worry about using the cleaner. The coating on the throttle body is to keep the carbon from building up on it. If you need to clean the throttle body, the coating is not working anyway. And it is more important to have a relatively clean throttle body than it is to try and preserve some coating that never worked very well.
Diagnose your sticky throttle problem BEFORE you remove the throttle body for cleaning.
Old 10-03-2016, 12:32 AM   #12
Yeah i will try doing what you said and if not ill try cleaning it and if that doesnt work than im not sure
Old 10-03-2016, 12:36 AM   #13
Keep us posted.
Old 10-08-2016, 09:10 PM   #14
How small do your hands have to be to get to the cable on the gas pedal? I cant reach it at all
Old 10-09-2016, 04:36 PM   #15
So i got the new cable attached to the throttle body but it only opens up half of what it did before
Old 10-10-2016, 09:51 PM   #16
I'm trying to envision how that would be possible. Unless, perhaps it is the wrong cable?
Old 10-10-2016, 09:55 PM   #17
I think it is
Old 10-10-2016, 09:58 PM   #18
Did the original cable seem to be the cause of the stickiness?
Old 10-10-2016, 09:59 PM   #19
Yeah it definatly was the old cable, going into ford tomorrow to get an oem cable
Old 10-11-2016, 10:02 PM   #20
So ford doesnt make them anymore and i got another one today and it had the same issue, the throttle body only opened half way
Old 10-11-2016, 10:15 PM   #21
If your original cable seems undamaged, perhaps you could try lubricating it with some cable lube, commonly used on motorcycles. Maybe that will free it up.
Old 10-11-2016, 10:29 PM   #22
No the old cable is frayed and you can see the cable inside
Old 10-11-2016, 11:46 PM   #23
It seems crazy to me, but it looks like there isn't a quality aftermarket OEM style throttle cable available for the Fox body cars... Aside from the piece of crap cable that is too long!
If you can't find a suitable replacement locally, I believe that Lokar makes a cable that can be modified to work.
Your only other option is to find a used one... Possibly eBay???
Old 10-11-2016, 11:48 PM   #24
Lokar? What modifications have to be done?
Old 10-12-2016, 12:05 AM   #25
I'm not exactly sure what all is involved but I don't think that it is too difficult.
If you Google it, there is probably some information about installing a Lokar throttle cable into a Fox.
Old 10-19-2016, 07:13 PM   #26
Haav2's Avatar
I found out why my throttle was being sticky. I pulled the throttlebody and actuated the throttle spring with my hand and as I let go of the throttle and the flap closed it would get stuck. So for my case it's the the actual tb.
89 gt
5.0 roller bored .20 over
Sealed power Pistons
Vortec v3 11psi
Gt40 heads
Bbk 5001 intake
3.73 gears
Custom exhaust system
Clutch Pedal to Close to the Brake Pedal S Marquard 2011-2014 Mustang GT 1 03-28-2016 09:21 AM
Sticky brake pedal or imagination. 14 mustang 4lexC 2011-2014 V6 Mustang 16 08-09-2015 06:48 AM
Shaking clutch pedal until pedal is pushed GHO5T5NIPER 1996-2004 Mustang GT 78 05-03-2015 11:47 PM
Finally did the gas pedal mod !!! Danger Dude Pre-2005 V6 Mustang 55 09-11-2004 08:34 PM
Gas pedal fix OR_Red98 Pre-2005 V6 Mustang 2 08-18-2003 06:59 PM
01:11 AM
