vortech v3. Can i change the diverter/bov for a better sounding one? - Mustang Evolution
Old 10-15-2016, 06:52 PM   #1
Haav2's Avatar
just wondering if i can swap my bosch diverter valve for a better one in order to get the nice sound you get when you decelerate a turbo'd car.
Haav2 is offline   Reply With Quote
Old 10-16-2016, 08:05 AM   #2
parkerz28's Avatar
Yes but you need a blow through mass air setup. In short your mass air sensor would have to be after the blow off valve.
parkerz28 is offline   Reply With Quote
Old 10-16-2016, 10:11 PM   #3
Haav2's Avatar
Maf after the bov? Btw my supercharger isn't intercooled.
My current setup is:
Tb to vortech pipe. (Pipe has a hose coming off of it to a Bosch bypass valve then continues to power pipe)
Vortech pipe to blower.
Blower to power pipe
Power pipe goes to maf
Maf goes to air filter.
Hope this can be understood
89 gt
5.0 roller bored .20 over
Sealed power Pistons
Vortec v3 11psi
Gt40 heads
Bbk 5001 intake
3.73 gears
Custom exhaust system
Old 10-17-2016, 08:20 AM   #4
parkerz28's Avatar
The reason the maf needs to be after the blow off valve is so the computer knows how much air is going into the engine. Right now with your setup the air is metered and then redirected back into the system when your valve opens. The blow off valve you want vents to the atmosphere and gives the cool sound your after. And yes most system are intercooled that use the blow off valve.
Old 10-18-2016, 08:04 PM   #5
Haav2's Avatar
Ok so I just move my maf up next to the throttle body? Then I switch to an aftermarket bov? What kinds are you guys running with your blowers.
89 gt
Vortec v3 11psi
Gt40 heads
Bbk 5001 intake
3.73 gears
sorry, double post. Haav2 1979-1995 Mustang GT 0 10-15-2016 06:51 PM
Need better sounding mufflers than stock rinfield2004 Pre-2005 V6 Mustang 9 09-13-2014 07:36 PM
Vortech bov tial Moto111 General Mustang Discussion 0 06-22-2013 09:10 AM
Which BOV ? Nathan69 2005-2010 Mustang GT 1 01-12-2011 09:32 AM
So which BOV should i use? 1996stang 1996-2004 Mustang GT 41 05-20-2007 10:18 PM
10:21 AM
