Best Engine for a Foxbody - Mustang Evolution
Old 11-29-2016, 12:07 AM   #1
Jagel5.0's Avatar
I plan to purchase a Foxbody in the near future but was wondering what would be the best engine to look out for in a Foxbody. I've heard I could just stick with the 302 but I've also seen 351C and some 351W out there and was curious which would be best for power for price. I'm not looking to get a 10 second car but anything around 400-500 RWHP would be suitable to my Needs.
Jagel5.0 is offline   Reply With Quote
Old 11-29-2016, 08:54 PM   #2
smurf stang's Avatar
The best engine is the one you can afford. Making that kinda power is attainable with either a 302, 347, 351, 408, 460 and so on. The wallet is what will hold you back.
2016 VW GTI 2.0 Turbo
Old 11-29-2016, 10:56 PM   #3
Jagel5.0's Avatar
Very true well said.
Old 11-29-2016, 11:19 PM   #4
LSx
Old 11-30-2016, 02:26 AM   #5
Jagel5.0's Avatar
---------- Post added at 04:26 AM ---------- Previous post was at 04:26 AM ----------
Originally Posted by straybullitt View Post
LSx
Lol no
Old 11-30-2016, 09:55 AM   #6
If you are against the LSx motor which is truly a cheap or should I say affordable way to make some power you could go with a 351 motor outta a truck but then skies the limit.
Old 11-30-2016, 12:01 PM   #7
olerodder's Avatar
Region: Oregon
Having built a number of 500+ hp 351's...that would be my second choice. My first choice would an LS3 or even an LS6 if you can afford it. They are lighter and pretty simple to make 400/500rwhp without breaking the bank. Making a 500rwhp 351 stroker will cost some serious dollars...especially if you want it to be reliable. I think 302 based motors are just too few cubic inches...the more cubic inches means more cubic torque...and that all adds up to more HP.
If you could find an LS3 out of Grand Sport Corvette it already has a dry sump which could allow you to lower the motor in the chassis or even slid it back just a little...just a thought.
Just so you're clear hear, 500rwhp in a relatively light Fox Body and some good suspension work will most definitely put you in the 10's.
LS3 wet sump, 405lbs
LS3 dry sump, 466lbs
351w is 575lbs
A 100 to 200lbs off the front end will make the car handle like a go cart...IMHO
Old 11-30-2016, 12:53 PM   #8
Jagel5.0's Avatar
351w is 575lbs
Well thank for that info I'm really new into going about building a Stang my first 97 GT was bone stock. And my 95 5.0 just had Heads and Intake just A few bolt ones nothing major. I've heard all the time of everyone saying doing a LS Swap on Foxbodies but I feel like it's against my will to do so lol. I know those LS1s or even LS3 are out there going out for cheap. But what about doing a Coyote swap I've seen them from time to time on sale on Craigslist for about 2-3k used. Or what about the 4.6 out of a cobra and then slapping a SC or Turbo on it?
Old 11-30-2016, 01:36 PM   #9
olerodder's Avatar
Region: Oregon
Since I'm older than dirt and have been racing for almost that long I'll say that back in the past I thought the it was a sin to put a Chevy in a Ford...it's all about the most bang for your buck. Also, I'm a N/A guy, and believe in all motor.
You can take a turbo/N2O/Supercharger and make tons of HP and TQ...at what cost????
I had a 97 Cobra...pictured in my garage...and the last thing I did was put a Whipple Charger on it...sure it would run really hard...until it broke ring lands on 2 pistons. The smart thing would have been to replace the weak OE rods and pistons with forged and it wouldn't have happened. You can use a 4.6DOHC as long as you are planning to build the motor with good parts and not OEM.
Kind of like the same with the Coyote...there are a lot of people out there making over 600rwhp on basically stock motors and that's great...for me it would never work as I'd be constantly worring about the rods or pistons coming apart...If you've got the money buy a Ford Aluminator crate motor and not worry. Just my two cents worth.
My last 351w stroker...408...had a single 850 carb and make 650hp at 6800rpm and 544lbft at 5700rpm on the engine dyno...pushed my Maverick to 9.801 in the quarter...so????
The old saying is, "How fast do you want to go????, Just look in your pocketbook". If you want to build a 408 you should plan on $10k for parts and machining...then you need to find a late 1971 to 1974 351w block as they have 10lbs of extra material in the main web and can be fitting with 4 bolt mains...how do I know...I've built more than a couple of these.
https://youtu.be/KFkOy0F5hGg
Old 11-30-2016, 02:04 PM   #10
LS.
Pick your poison.
Recon is online now   Reply With Quote
Old 11-30-2016, 02:29 PM   #11
Jagel5.0's Avatar
Great video gives me a good outlook on things. I would personally be okay with a Coyote Swap but I'd have to look into price and how much that Crate motor you mentioned costs
Old 12-01-2016, 12:58 PM   #12
cjsilen's Avatar
Region: Nebraska
Buy a brand new coyote that already has 435 horses, is very reliable and lightweight. You can get a new one for 5 grand or low mileage for around 3 grand...
R2014 Shadow Black w/Ruff 20x10 Black and Red custom painted wheels, 3 inch Borla racing exhaust, Cobrajet intake manifold throttle body and CAI, MGW Racing spec shifter.
cjsilen is offline   Reply With Quote
Old 12-01-2016, 02:41 PM   #13
Yeah but swapping a new Coyote still will take plenty of parts that add up to more money.
Good read.....
http://www.mustangandfords.com/how-t...v8-swap-guide/
Setting a budget is always first on the list.
Old 12-01-2016, 03:54 PM   #14
olerodder's Avatar
Region: Oregon
What SmurfStang said is the first thing you should do. If you don't have to budget to do what you want then you need to look at other alternatives.
I have never seen a new stock Ford Coyote crate motor for less than $6k, and the Aluminator is around $9k. Yes, there will be a lot of other stuff before the Coyote will run, electronics and other stuff will eat up another $2k.
As I said earlier...to build a real 500rwhp motor will easily take $10k. Even if you build a motor and add a blower/turbo you will need to spend some money making sure it doesn't come apart the first time you put your foot on the floor.
I have a friend who goes to salvage yards and buys LS motors, puts a turbo on it and runs it till it blows up...the motors usually cost him anywhere from $500 to $1000...You could get a lot of experience pulling motors...just a thought.
Remember, how much HP you want depends on how many green backs you are willing to spend.
foxbody
Foxbody engine help Murdered5.0 1979-1995 Mustang GT 9 12-04-2015 02:51 PM
Foxbody engine help Murdered5.0 1979-1995 Mustang GT 0 11-28-2015 06:40 AM
Foxbody 5.0orGTFO Regional Mustang Discussion 2 03-28-2015 02:41 PM
My foxbody Turbodave5.0 New Member Introductions & Greetings 10 12-01-2011 04:37 AM
New foxbody 04machazblue 1979-1995 Mustang GT 23 10-13-2011 08:34 AM
02:05 PM
