Starting problems - Mustang Evolution
Old 09-10-2017, 08:29 PM   #1
Starting problems
I've changed out my ignition switch tested my starter and it's all good my battery is good also I changed out my starter silinoid and the cable running from the silinoid to the starter still can't get it to crank over at all. Anyone got any suggestions thanks
Tyler129 is offline   Reply With Quote
Old 09-11-2017, 10:14 AM   #2
JimB.'s Avatar
I know this may sound like me being a smart *** . Is it an automatic , is it all the way in park ? If it's a standard it could be the switch on the clutch pedal.
JimB. is offline   Reply With Quote
Old 09-11-2017, 05:36 PM   #3
Hi yes it's in automatic and I have it in park all the way I've just ran out of ideas
Old 09-11-2017, 06:07 PM   #4
Revvv's Avatar
Put it in neutral and try to start the car.
Old 09-11-2017, 06:20 PM   #5
Tried that to
Old 09-11-2017, 06:57 PM   #6
jeno's Avatar
Are you sure the starter is good
jeno is offline   Reply With Quote
Old 09-11-2017, 07:23 PM   #7
I took it to autozone to have it tested and they told me it was good I even changed the wire tuning to the silinoid to the starter
Old 09-11-2017, 09:25 PM   #8
You need to get a probe-style 12V test light, and start checking around to find out what is not getting voltage.
What year is the car?
Old 09-12-2017, 04:02 AM   #9
It's a 91 lx
Old 09-12-2017, 06:16 AM   #10
Revvv's Avatar
You are going to need to check the fuses and relays for the ignition, starter, etc. If they check out, you will need to check the continuity of every wire leading to the ignition and starting components.
Don't forget to check the operation of the ignition switch (not the key switch, but the box the key operates), the park/safety switch, ground to the starter, ground to the fuse box...
Basically, get a wiring diagram and begin pulling things apart slowly and methodically.
Old 09-12-2017, 07:12 AM   #11
jkeaton's Avatar
Wrong section......
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 09-12-2017, 07:57 AM   #12
Revvv's Avatar
Originally Posted by jkeaton View Post
Wrong section......
...but only a mod can move the thread.
Old 09-12-2017, 09:30 AM   #13
jkeaton's Avatar
Yep....been reported.
07 V6 Coupe
Old 09-12-2017, 11:00 AM   #14
Check the ground...battery to block, block to body...good luck.
IamNeo is offline   Reply With Quote
Problems starting strips 2005-2010 V6 Mustang 9 10-02-2014 12:00 AM
Starting problems tdawg 1996-2004 Mustang GT 0 12-14-2013 04:03 PM
Starting problems 94GTpony 1979-1995 Mustang GT 1 10-12-2012 09:07 AM
Different Starting Problems milkrun49 2011-2014 Mustang GT 3 07-15-2011 03:19 PM
Starting problems! 99 SVT Cobra 1996-2004 Mustang GT 2 01-10-2010 05:47 PM
04:01 AM
