'95 GT Stalling at idle with AC on - Mustang Evolution
Old 09-28-2017, 05:25 PM   #1
I have an issue with my '95 GT where it runs perfect with the ac off. When I engage the ac it is fine until I stop at a traffic light. If I keep the ac on, the engine seems to "load up" . When I go to take off from the light the engine stumbles, spits, and sputters and I can smell raw gasoline fumes. It is bad enough, in order to get the car moving, I have to turn off the ac, and then the engine will clear up and run normally. If I turn off the ac prior to getting to the light it is fine and doesn't show any of the above symptoms and it runs normally when I start out from the light.
Frustrating!
Any help or suggestions you have would be appreciated! thanks!!
Mr.Blue is offline   Reply With Quote
Old 09-28-2017, 08:08 PM   #2
Revvv's Avatar
The A/C compressor could be bad or overcharged, which will eventually blow out the seals and destroy the compressor.
You may also have an alternator problem. It may not be able to keep up with the extra load.
Old 10-03-2017, 03:17 PM   #3
smurf stang's Avatar
Maybe a vacuum leak.
2016 VW GTI 2.0 Turbo
Old 11-18-2017, 12:26 PM   #4
Sorry for late answer, I just signed up. I think the battery if it's any good, would contribute any lacking power if the alternator output is low.
65 k car is offline   Reply With Quote
2003 Mustang GT V8 Idle / Stalling issue Haleybug Mustang 101 - Tech Basics | Ask an Expert 1 05-09-2017 12:42 PM
Intermitent stalling at idle? 01 bullitt 1996-2004 Mustang GT 4 04-27-2015 06:26 PM
Surging Idle, stalling, and fuel pump Alex5123 1979-1995 Mustang GT 4 09-01-2014 07:13 AM
95 gt cold start, stalling at idle issues.. need help BloodRedStang 1979-1995 Mustang GT 3 09-02-2013 09:31 AM
Stalling/rough idle after start up? brianw64 2011-2014 Mustang GT 11 12-18-2012 07:53 PM
04:30 AM
